3.2 engine to '76 915 transmission
Old 11-07-2001, 10:28 AM
MarkB
3rd Gear
MarkB's Avatar
Post 3.2 engine to '76 915 transmission
Can I use the 3.2 flywheel, also do I use the 3.2 clutch, I have a brand new 2.7 clutch and would like to it, if possible
Old 11-07-2001, 11:51 AM
Howard
Howard's Avatar
Post
This topic was covered just before the "crash",Im not sure if it's been archived or not, but if I recall it went something like this:
If you retain the DME from the 3.2 you'll have to make a cut out in the bell housing to clear the sensors for the flywheel, if you go with carbs and/or some other ignition you won't have a problem. The flywheel has to be a 3.2, again if you're going with DME. IF not, you can use a flywheel and clutch from a 2.7, 3.0, or 3.2, I have a clutch and flywheel from a 3.0, a 915 trans and an '84 3.2 case in my car, so I know that combination works.
Good luck !
Old 11-09-2001, 12:28 AM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Post
Good advice,.......Howard is right on, except of the flywheel issue.
The 2.7 uses a 6-bolt crank and the 3.0 & 3.2 use a 9-bolt crank.
You can use an SC 3.0 flywheel for carbureted or MFI'ed applications but should you choose the Motronic, you'll need the 3.2 flywheel to retain the trigger for that system.
Quick Reply: 3.2 engine to '76 915 transmission
