PTV & disabling PASM
Old 09-17-2018, 02:41 PM
Squeaky
Squeaky's Avatar
Default PTV & disabling PASM
Does anyone know if PTV functionality will be affected if PASM is disabled by installing a non-PASM coilover or PASM "delete mdule" in a PASM 981? I'd like to think they work independently but Porsche seems to have a knack for tying systems together with the toggle buttons, especially since PASM is tied to the PTV as an option.
Would be great to hear from anyone with experience. Thanks!
Old 09-18-2018, 11:58 AM
Scooby921
Scooby921's Avatar
As far as I recall from the vehicle build options PASM and PTV are independent. PTV is tied to PSM (stability control). If you fully disable ESC then you turn off PTV. The PASM suspension shouldn't have any impact as you could also order PTV on an X73 equipped car which has no active control or feedback.
Old 09-21-2018, 02:05 PM
Squeaky
Squeaky's Avatar
Not sure if this was the case before, but if you go build a Porsche on their site, PASM will be added if you add PTV onto a Cayman S.
So I guess what you're saying is if I turn PSM off, PTV deactivates and I'm basically have a mechanical dif?
Old 09-21-2018, 03:59 PM
Scooby921
Scooby921's Avatar
To the best of my knowledge, yes. It's always a purely mechanical differential. PTV might switch the physical hardware from open diff to limited slip diff, but the actual "vectoring" function is a brake-based component. When the inside wheel loses traction and starts to spin PTV will apply a little brake pressure. This increases the torque at the low friction wheel allowing the torque biasing of the differential to send more to the other wheel. It's effectively an advancement in ESC technology. Fully disabling ESC (PSM) tells the brake controller that you don't want any assistance, thus eliminating PTV as well.
Because PTV is a brake-based feature I don't see how the presence of PASM would impact it. I can see Porsche linking them together from a performance aspect and forcing you to spend more money on a "package", but I can't see any reason why PTV needs PASM dampers or PASM dampers need PTV in order for them both to function normally.
Old 10-06-2018, 07:29 PM
blink21me
blink21me's Avatar
Interesting. If that's exactly how PTV works in relation with PSM being disabled, then I may have wasted time waiting for a 981 CS with PTV to turn up in the classifieds. Plan is to build a moderately modded 981 Cayman S autocross machine and aftermarket coilovers is #1 on the list...
Old 10-08-2018, 12:39 PM
Scooby921
Scooby921's Avatar
Well, a PTV equipped car does get a mechanical limited slip differential. Even if disabling PSM does disable PTV you still get an upgraded differential with it. Not a major issue if you're preparing the car for a class that allows a differential upgrade, but possibly worth it in Street/Stock classes.
Old 10-09-2018, 02:22 PM
GTgears
GTgears's Avatar
The mechanical LSD is a joke. 22/27 locking factor and clutch plates that fall apart after a couple of events. The adhesive holding on the little pucks fails with heat and they just slide around on the plate getting stacked up in piles 2 or 3 clutches thick.
Quick Reply: PTV & disabling PASM
