PIWIS coding: Catalog of Features + Discussion
#31
This thread is intended to discuss & collate the features that can be enabled, disabled or otherwise changed through PIWIS coding specific to Panameras.
For discussions on how to obtain, activate, setup, connect, or troubleshoot the underlying PIWIS software and hardware, refer to active threads under the Panamera area here (procure / setup) and here (connect / use) .
I will update this table of contents so it will be easier to navigate as this thread grows. Reply for requests and if you have codings to add! MODS, feel free to edit.
Below is my starter list of confirmed codings on a 971 4EH. Shout out @Andy Liu @rnlst_log @siberian
Via Maintain Vehicle Data
Instrument cluster coding (E mode manual coding; control unit Kombiinstrument):
Body Control Module 1 (E mode manual coding; control unit BCM1)
Body Control Module 2 (E mode manual coding; control unit BCM2)
CarPlay features (E mode manual coding; control unit MIB2 Zentralrechner)
Possible features that I have not personally tried if anyone can confirm:
My wishlist requests if anyone’s successfully coded:
Happy coding!
- Porsche Sport Exhaust coding (V or E mode)
- Power Steering Plus coding (V or E mode)
- Sedans-only: turbo spoiler retrofit coding
- Disable seatbelt warning & chime: kodierwert > codierbyte 00: gurtwarnung Fahrer, Beifahrer, USA, NCAP > 'nicht aktiv'
- Passenger airbag activated / deactivated warning messages: warnungskonfiguration: Byte 4 39 Beofahrerairbag deaktiviert and 4 40 aktiviert > 'nicht aktiv'
- Welcome screen model designation: kodierwert > codierbyte 5 welcome screen ID > your choice e.g., Panamera, 4, GTS, 4S, Turbo, or any other
- Rear LED + sidelights on with DRL
- Deactivation of orange side markers (for euro bumpers) kodierwert: Bitfield side marker config 'not installed'
- Deactivation of headlight washers kodierwert: Bitfield head lamp wash 'not installed'
- Parking Distance Sensors (PDC) deactivation speed PDC maximum speed: your numerical value in KM/H
- One-touch turning signal flashes: Flasher_light_control > Motorway_flashing_flashing_cycles > your choice of numerical value
- Windows and sunroof up & down with key fob (for our 4 doors, add rear driver / passenger windows)
- Unblock lists: nhtsa_properties > nhtsa_limitation_switches_for_carplay_limit_nonMusicLists 'not active'
- Unblock music lists: nhtsa_properties > nhtsa_limitation_switches_for_carplay_limit_MusicLists 'not active'
- Soft Keyboard: nhtsa_properties > nhtsa_limitation_switches_for_carplay_no_softKeyboard 'not active'
- PASM vehicle height adjustment?
- Activation of matrix LED high beam assist?
- Intersection lighting?
- (‘19+) built-in Wireless CarPlay activation?
- Turn OFF sidelights with above rear LED DRL coding (i.e., DRL = front quad lights + rear LED only)
- Video-in-motion (testmode video speed under MIB2 does not write for me)
- Close tailgate with key fob
Happy coding!
the close tail gate, i end up buying a hanress it was like 40 bucks and it does it
#33
Has anyone with a U.S spec/North American 971 Panamera changed their tail lights to the EU/RoW version with the amber indicators and coded them to work correctly? I did the same with my Taycan and trying to research how I can code them to function correctly. There doesn't seem to be too much coding support in the Taycan world, so I thought I'd ask here.
#35
I have 970 TurboS but have never seen this option - any clue where it is found in PIWIS?
#42
The following 2 users liked this post by Marcus13190:
sac02 (03-14-2024),
World Player (09-20-2024)
