CPO issues, what to do?
#121
Maybe time for a forum poll to see whose car has it and when it occurred. I've noticed this forum doesn't show model info in member's signature so you can see what one they have when posting. Would be helpful.
#122
Were you getting the vibration when the rear spoiler wasn't working? Reading through the threads again the vibration seems to occur in Panameras at around the time the spoiler goes up. This could change the aero dynamics of the car.
#123
I normally drive in Individual mode, no spoiler. But, I have checked with spoiler up, down, different suspension settings and gears at same speed. Does not change the behavior nor with 700lb in the trunk.
it occurs, 54-56 to 62 mph, hold speed steady and about 10-20sec at this steady speed there is a hormonic vibration/ bounce that will be felt.
#126
Bumping this since I have a GTS on order and now I'm confused/worried.
In the later part of this thread, it seems like we think the V8 powertrains aren't affected, but the OP had this issue on a Turbo trim. Or were we just saying the V8 Cayennes arent affected?
#127
In the Cayenne forum it seems the V8s are not affected. In the Panamera forum I don’t think anyone has summarized which powertrains have the vibration and which ones don’t, if any.
#128
I can confirm this in a 2020 Panamera 4S. Have tried multiple sets of rims and tires to no avail. It seems to be less noticeable with tire pressures under 37psi.
chassis (08-18-2023)
#130
Is there a resolution/idea on this topic? I am now dealing with this.
I just picked up a 2020 GTS with 27k miles and I noticed it on my first test drive. I thought it might be a wheel issue. I did not really notice it on a second test drive. I stupidly purchased the car and mentioned it to my salesperson and the general manager. I purchased the wheel and tire plan without concern and the dealer agreed to address the issue if I noticed it post delivery. Of course the car wobbles as per this thread (although across a variety of speeds) and the first session with the dealer had the head mechanic confirm the issue and say they struggle with fixing it. I drove home and then reconsidered to have it officially on record as my daughter refuses to sit in the back of the car and made another appointment in a week. I have less than 500 miles on the car since purchase and I find it annoying. I love everything else about this vehicle except this is really frustrating.
It does not feel like a wheel issue as everyone else has mentioned. It comes and goes and my initial reaction prior to reading this thread is that it has to do with the air suspension or the controller.
#132
Congratulations on the purchase! The Panamera GTS is great despite the vibrations. It's unfortunate that this is an ongoing problem with a $150k car. Porsche needs to get their act together.
#133
Yet again I had my GTS at the dealership for service. (My rear spoiler once again sh%t the bed. This time it was not mechanical but a control unit.) While it was there I made them aware that the 57mph vibration has become worse and is now accompanied by a vibration at 28mph, all in hopes that the problem could more easily be identified now that it has gotten so bad. They said they test drove it, gave it another complete inspection and, once again, told me this is an ongoing problem with 4WD Panameras and that they have no remedy. They are also seeing this problem with some Cayennes.
So I yet again contacted PCNA. They said they would investigate the issue and contact the dealerships that have serviced my Panamera to gather the complete set service records. They responded after a few days once again stating that the vibration is a “harmonic characteristic” of the Panamera and the vehicle is operating normally, blah, blah, blah. No help, again.
I contacted Porsche Club of America and some of the Board members responded with a few interesting observations including:
"28 mph is almost exactly half of 57 mph confirming that this is a harmonic, or at least periodic with WHEEL speed (not engine, not transmission, WHEEL speed)" and "I suspect (educated guess land now) that what has changed is that bushings are not as tight or not as pliable."
I completely agree that this is periodic with wheel speed, not wheel or tires per se, also but not engine or transmission. I still have my suspicions with the front differential. Also, I have noticed that the car has more "slop" in the drive train. Rapid throttle inputs create the sensation that the drive train is moving within the chassis--more than when new. Also on a launch, there sometimes is a thud that sounds like a busted trans mount. (This also was checked by the dealer and they say that too is normal.)
Has anyone changed any bushing or mounts (such as transmission or motor mounts) in attempt to lessen the vibration?
#134
Great observation.
My car sat 2x times this summer while traveling. After first trip which lasted 20 days, vibration was awful at any speed for the first 3 miles, then better.
2nd time the vibration was as normal. I have also noticed if I go on long road trip, 2-3 hrs vs 30 min, vibration seems to reduce. If the diff, there is none to very minimal change in temp in diff between a 30 min vs 2 hrs. Should be at max. for either and there should be no difference in vibration if mechanical
Im back to tires. Just received Michelin Pilot Sport 4S. Next week I will bring car to shop, check all wheels for roundness and install the Michelin. Current tire is Pirelli all season. Google Pirelli flat spotting. Checking wheels for roundness is for peace of mind.
I will report back in a week or so on my result.
