How many miles until new rotors/pads?
I'm approaching 60k in my 2013 GTS. Dealership is telling me 3-5k more miles and I need new rotors and new pads-- sound right? I was hoping just pads or nothing at all needed for some time... normal driving, no tracking.
Thanks!
Thanks!
How long do you expect a performance sedan’s brakes to last? This isn’t an Accord.
DMoore
'18 Panamera Turbo ST
'18 Carrera GTS
I honestly thought the days of changing pads and leaving the rotors were over about 15 years ago for European marques.
I don't know why that would be the case, other than the same old trick of getting owners to pay for rotors when you don't need them. If you're hard on the brakes they are going to wear out faster. I'm sure changing pads and not rotors is viable for some cars still. Audi RS7 brakes wear out way faster and cost way more than the Panamera from my experience.
Rotors will be in good shape as pads wear and need replacement.
Issue is if you want to machine panamera turbo rotors, they are two piece, means machining will be hard as two piece rotors create vibration that may cause uneven machining.
Some shops wont want to do. I just did this to my front rotors, with good result, but still feel slight vibration when braking. Added new ceramic pads.
So in near future I will be putting on new rotors and another set of new pads to make sure my car is 100%.
With ceramic rotors, pads will wear out and rotors will be almost new. So only pad change is needed, but you then fall into the scenario of whether or not to machine rotors before putting new pads on them. I would machine, as only perfect smooth surface will give you good feel.
Going through a bedding process after installing pads is important and makes a huge difference. I did this to a friends Audi as they were to scared, after the brakes started squeaking post new dealer install. Dealers don’t bed the brakes typically.
Bedding helps match new pads with new or old rotors which reduces noise, inconsistency in feel, and surging.
https://www.zeckhausen.com/catalog/i...Path=6446_6443
It's hard for me to know if I really new need new rotors or if my dealer just sees it as "best practices" (and to grab a few extra bucks in labor and throw a bone to his parts pals). I can get a "second opinion" from a indy mechanic, but then it becomes a "who do ya trust". From this thread, it sounds like 60k is about the time that new rotors are needed. I definitely need new pads. So, I'll probably suck it up and do both. Does $4500 all-in sound about right (rotors, pads, other misc related parts, labor)? That's the quote I got from dealer. Thanks!
