Front License Plate
#31
#33
#34
Now this I like! I'd not heard of them before, but may put an order in... Anyone put one on a 971?
#35
I had one of the Millworks mounts for my 997TT. I backed over it a couple times to scratch it up slightly, and stuck it under my seat. I got pulled over once for going through a small town kind of slow (who knows why?), and I just said "it fell off - but here it is". In MN, BTW, where it is mandatory unless your car is a 'collector'.
#36
lmao, you drive a >$100k car and you're worried about a $50 fix it ticket (which is only $50 if you dont fix it, if you do it's like $10)? I've driven around in CA the past 15 years without front plates and only got a front plate ticket 2 times. Well worth the $100 to not put it on.
#37
#38
#40
#41
#42
You could try a magnetic setup like this https://rennlist.com/forums/991/1021...ate-mount.html
and keep it in the back. If you are pulled over just say you pulled it off for the car wash, airport etc. and forgot to put it back on. Drive around with it on in the summer for a day or so to get that authentic bug splatter/used look.
#44
Made my own license plate holder for about $25. Home depot, bought 2 pieces of strip stainless metal. Cut and drilled holes and mounted it. Came out great. No drilling into the front of the bumper and didn't use the tow hook option as I didn't like the offset placement of the license plate. If you have a drill and a hack saw and a few machine thread screws and nuts all able to be purchased at home depot. Took me about an hour to cut and drill the holes and 20 minutes or so to install it.
