Flat6 fixed height lowering links
Looking for anyone with a GTS that has the standard air suspension (not the optional 10mm higher) that have the Flat6 fixed height lowering links installed. I want to see how "low" the car sits in the lowered setting. On my previous GTS I had the CETE lowering module but once I set it, I never adjusted it again. So I think the fixed height lowering links will work for me ( $$) BUT I am afraid that the 1.25" lowering over the standard lower height might be a tad more than I want but I'd really like to see some pics. I prefer side pics vs these angle pics some have posted as it would show the height better. Also if you can comment about how much gap remains.... 1 finger, 2 finger or in inches. Thanks in advance!!
NickS (02-05-2024)
Update: Installed the Flat6 fixed lowering links and Flat6 wheels spacers this weekend. Gotta say I LOVE the stance and presence now. Perfect IMO.
PASM set to low - Flat6 fixed lowering links
PASM set to low - Flat6 fixed lowering links and Flat6 wheel spacer kit
PASM low setting with Flat6 fixed lowering links
Standard PASM low setting
The following 4 users liked this post by NickS:
NickS (02-05-2024)
Which install is correct? I'm going to assume "A" to allow movement of the socket/joint?
NickS (02-09-2024)
What does it look like in the Off-road height now?
Then "A" as that is how I interpreted Flat6 images I saw online at the time of install. I messaged Flat6 the same question with my 2 pics and they never replied and have yet to reply. Not really happy about that but whatever.
I installed them as shown in "A"
tourenwagen (02-15-2024)
I had the Flat 6 set and didnt like that they had the same size bolts for both 10mm and 12mm spacers. Its only 2mm but still nice to have maximum thread reach. Its not fun to have two sets of bolts either, one for 10mm and one for 15mm so 15mm all around is likely best. H&R is also much better quality than the Flat 6 hardware.
mark8 (04-16-2024)
