Just Purchasing a Porsche Extended Warranty...
I'm just about to pull the trigger for an extended warranty on my 2018 GTS, from Porsche. Apparently it's something they offer, vs Fidelity etc...
After my experience with fairly major post-purchase repairs, and an existing extended warranty that covered them (now just recently expired), I think I'll carry on with having one.
Besides the warped leather dash, cam cover gaskets and air suspension sensors, does anything know what else can go wrong with these? PDK? Turbos? Water pump?
Thanks,
JP
Thanks,
JP
Basic Sponsor
Just remember because depending on the dealership, things may not be as clear, but it is not a "Porsche Warranty", but a third party warranty provider Porsche finance has their name too, all legal insurance information in the contract will reference the 3rd party provider.
Your place for distinguished automobiles, proud provider of Fidelity & Freedom Warranty extended warranties. Visit us at Highline-Autos.com
Official RECARO Automotive Retailer: www.highline-autos.com/product-category/recaro/
Highline Autos Magazine - Volume XXI, Issue 03 https://bit.ly/3wTsNzM
Zeus993 (01-10-2024)
The following 2 users liked this post by Faust T.:
Highline-Autos.com (01-10-2024),
Thanks,
JP
Thanks,
JP
I purchased the factory warranies directly from Porsche for my 2022 when new. They have a bewildering selection of policies. Besides the main defects coverage (7 years I think which is only 3 additional years on the 4 original), which does not cover headlight modules and PSCB brakes (two extemely expensive "consumables"). You have to add "term" coverage to that to have headlights and those very expensive WC coated rotors (one set). I also added maintenance coverage wich includes standard routine yearly service. Some think this is not cost effective, but when you get to later years with plugs, serpentine belts, etc at an expensive CA dealership, the cost turn out to be a bargain.
So some continured piece of mind, after dodging the post-purchase bullet. We'll see how the car continues to fair, fingers crossed.
Thanks,
JP
Thanks,
JP
The mechatronic unit in the macan pdk is one of the larger cost items. Many dealers will sell a whole PDK when a mechatronic unit will repair that failure. Mechatronic units often fail around 100-110k miles. Clutch modules have been seen to fail ( leakage between the large and small clutch chambers not generally for slip) in the 120k range.
Is there an advantage to getting an extended warranty while the car is new or near new as opposed to towards the end of warranty coverage?
While anything can go wrong at any time, the majority of issues will be emissions control/ck engine light related failures. Radiator shutter, cooling system failures like any vehicle.
it had already cause enough damage to the internal that required a whole PDK replacement.
So that's not actually accurate. Failure in the mechatronic unit is most commonly shell bearing half 1 or 2 (oil control solenoids which are not availableas spare parts). There are other failures associated with mechatronic that are less common but the default is always limp. Its nearly impossible to drive the vehicle in a manner that could cause further damage and the instrument cluster will scream at the driver, reduced power output active. Mostly you lose Even gear exchanges or odd gear exchanges and reverse. In those cases the affected clutch plate has no oil pressure being applied and the control unit will not attempt to shift affected gear(s). There are a few things in the macan pdk that can fail that are not available as spare parts that would necessitate a whole PDK but mechatronics is not one of them.
jbx2 (01-21-2024)
Basic Sponsor
Russian Mafia (01-14-2024)
Basic Sponsor
I had an opportunity to study the Fidelity pricing structure and noticed that when a car hits 25k miles, the price of the warranty significantly increases - with all other variables remaining the same (same vehicle, length of coverage, mileage coverage, and deductible value.)
0-10K
10K-25K
25K-35K
35K-45K
45K... and so on.
The following 3 users liked this post by Highline-Autos.com:
