What is the 4 year service list (major items) 2020 Macan S
Car has 33k miles and will be about 35k by the service interval:
Oil / filter
Brake flush
PDK oil/filter
Spark plugs
air filter
cabin filter
Anything else?
Oil / filter
Brake flush
PDK oil/filter
Spark plugs
air filter
cabin filter
Anything else?
Thanks all
Big service, should I trade it? :-)
chassis (10-09-2023)
Is there a write up on PDK oil/filter change?
As well as the transfer box?
**Whats a dealership typically charge for something like this ? Im approaching 60K and I dont believe the previous owner has done this.
Low speed gear changes were definitely better afterwards but i do a lot of back roads so more gear changes apart from a couple of trips to Marseille.
NJR1986 (10-11-2023)
Did you do it yourself or this is thru dealer?
Appreciate that, I can sympathize with business, which is why I was hoping you took it somewhere for those rates. I wonder what the dealers here in the US charge for this kind of thing.
Here’s an idea…call your localPorsche dealer and ask them what’s included and what’s the charge.
Dealer labor rates vary widely around the country. The important thing to know is what is your local dealer’s rate. You could get several replies here, but they’d all be dependent on their local labor rates. My local dealer in Austin, TX charges $325 per hour. My doctor and dentist have lower rates.
chassis (11-14-2023)
The "transfer gear" is the north-south multiplate wet clutch torque coupling between transmission and rear propshaft. Easy job, just limited access and need to work under the car.
