Wheel locks
Wheel locks
Is there some sort of record (VIN coded?) for the wheel lock that comes with the Macan? Are they all different and individually coded or not? I ask beacuse I just about lost mine after putting my new HREs on the car (left it on the last wheel I changed) and almost drove off with it still on the wheel. Would have lost it for sure. Now I am thinking of getting a backup or spare just in case. But I am not sure how you would order one if they are specific to what's on the car.
I think they are specific to model, at most... certainly not specific to the VIN (that would require tooling for each vehicle sold). Most likely, they are specific to the lug nuts used, which could be used on several models.
DHL (08-11-2023)
CPRHDSRT (08-13-2023)
Thanks to rdubu and that link, I looked at my current removal key and found some numbers inscribed inside it. In my case "ABC 56", which corresponds to the 20mm 20 spline key. Will see if I can order from the dealer or Suncoast.
rdubu (08-11-2023)
I just bought 4 new standard lug bolts from Sunset since I swap summer and winter wheel/tire sets. Problem solved as I have no worries about wheel theft
