Rattle from Drivers door near Handle pull electrical window switches
I have an annoying rattle on my 2014 D S from an area either close to the drivers door handle Pull or behind. I have taken off the door card twice now and found
A cable running over the rubberised door access panel not clipped in and had been drumming on the panel. (-marks on cover)
A cable that moved slightly in its cable tie clip revealing bare cable and not wrapped anti-squeak tape.
Frustratingly after fixing both these issues the rattle remains. I have also checked behind the access panel to see if the foam cover is covering the contact point with the door and it is. (Not slipped down, which is another possibility from reading other forums)
I wonder if anyone has ever removed the Handle Pull from the door card to find something loose?
It only rattles on rough roads or pot holes. Any help appreciated, its driving me mad.
