Coolant level
Coolant level
My 2022 GTS has the coolant tank near the firewall under a vanity panel. How the freak do you check coolant levels? Remove that panel somehow? User manual implies you check levels by marks on the side of the reservior, but you cannot see this without removal of that panel. I tried looking down from the top with a mirror and the cap off, but could not tell where the upper level marking was. Earlier MY Macans had that reservior front and center just right of the motor and levels where easy to see.
On my 23 Macan S the coolant level is visible through the plastic grille area just to the passenger side of the firewall located coolant bottle. Not ideal but possible to get a quick check. Does your 22 GTS not have this grille?
Blu311 (07-31-2023)
I would presume it does (at least basis my experience with other Porsches) but I didn’t investigate further once I saw how easy it was to check the level. The key is a powerful flashlight. Removing the filler cap and shining the light down into the bottle makes it even easier - see this pic. Note that it was difficult to get the focus right with my iPhone and the min/max markings were way clearer to the eye. I highly doubt that removing the cover panel would be worth the hassle just to check the fluid level.
DHL (07-30-2023)
I didn’t take a pic but I did note that there is a little triangular cut out near the brake fluid reservoir that appears to be a viewing window for exactly the same purpose.
Found a YTube video from Pelican Parts that shows removal of that vanity panel. There are 4 hidden clips that must be accessed to remove it and they can be damaged easily if you just yank up.
See
See
