PSCB costs
PSCB costs
As I rack up the miles on my GTS I started to research costs for PSCB rotors and pads... $4300 for the front rotors on pelican (slightly less on suncoast)!! Really quite a jaw dropper
So a few questions-
-Benefit of PSCB is reduced brake dust correct? Is durability the same as steel?
- what is the equivalent steel rotor sizes and can they be swapped?
I've mentioned before that aside from the ridiculously small gas tank, this is a fantastic daily driver but the cost of this wearable item is outrageous
So a few questions-
Reportedly the durability is much better than standard steel brakes. I have read expected lifespan of PSCB pads and rotors is 90-100K miles with normal use. Of course that could vary depending on how you use the vehicle.
Some have reported they are more grabby, some have reported they are less grabby (who knows). Personally on our 2022 GTS I find them pretty grabby at low speeds, maybe a little more than desireable but you can adapt your braking style.
Brake dust is TERRIBLE w/ the stock steel brakes across all Porsches. That can be mitigated about 80% by changing to aftermarket ceramic pads like Hawk or similar. So that's an alternative that would address brake dust but not have the replacement costs when the time comes (more frequently, but if you are racking up big miles then maybe the way to go). Some worry-wort types would not be able to get over worrying about "voiding the warranty" with aftermarket pads. I am not in that camp of people so I am unable to comment on that.
chong0 (03-10-2023)
So a few questions-
So a few questions-
Our experience with our 2021 Macan GTS with PSCB is that they were VERY grabby the first 10K miles. They’ve improved somewhat since then (now around 23k miles) but still grabbier than steel or PCCB. But they also release essentially zero brake dust. In that way they are quite similar to PCCB. Love the zero dust but the grabby nature takes quite a bit of getting-used-to. We both adapted our braking style but even so, it can be difficult to be smooth with these brakes, especially at low speeds. But the zero dust makes up for it.
FLACHT6_pilot (11-09-2023)
Keep 'em clean. Seriously. I was this close to paying to have them removed from the car before I realized how important that was.
Besides the lower brake dust, I appreciate the fact they do not show rust after being wetted. Cosmetically, I like this better than a little brake dust, esp with open wheel spoke designs like my HREs. Nothing worse than the view of brown rusty rotors. I only have about 1000 mi on my GTS, and agree the brakes feel aggressive at low speeds. But they also feel really strong and pull down hard from high speeds. I have not been able to compare the performance of these vs standard steel rotors in another Macan, but compared to "upgraded" brakes" in a 2023 BMW X3 M40i I just traded, there is no comparison. These PSCB tungsten carbide coated are far superior.
Regarding the performance differential with the PSCB's - an additional factor is the size of the calipers with those brakes. The amount of surface area being contacted by the pads in those calipers is significantly greater than the standard Macan brakes.
That may account also for the "grabbiness" of them relative to what one might normally expect.
Terry Adams (11-06-2023)
If the grabby aspect was due to size of calipers to rotors, then PCCB should be even grabbier. I assume it it related to the compound of the coating, and the combination of that coating plus the pad. But I’m not a material scientist so it’s a guess.
In any case, for me….the lack of dust is worth the “grabby” nature. And I feel they’ve definitely improved with miles and maybe I’ve gotten better at adapting my driving style. My husband HATES the PSCB and on mutliple occasions has suggested he’d gladly pay to swap them to steel brakes. But that would not make sense and we’ll just keep driving it as-is. But we probably wouldn’t spec them again (or at least my husband would not). I might be willing to tolerate it on another car if PCCB isn’t available, especially since I now understand how to adapt to it.
The PCCB brakes on my 718 GT4 are quite a bit bigger than the PSCB on the Macan. We also had an RS with PCCB, and we’ve had Brembo CCB on other cars. We have NEVER experienced the “grabby” behavior until the PSCB. After our initial feelings about it (disappointed) we discussed with our service manager who had heard from others that they were grabby. Some people said they improve with more miles.
Historically with the Germans, form has followed function - but I think the Porsche marketers made the final decision on these - "Let's go with the shiny ones..."
needmoregarage (11-10-2023)
I took delivery of my 2024 GTS over the weekend and I can tell you that mine are not grabby at all. In fact I feel like the pads don't bite enough and I have to put more pressure on the brake pedal than my previous GTS.
Larry Cable (11-13-2023)
This is normal, it gets better. You need to give the brakes a few hundred miles to break in and allow the pads to fully seat with the rotors.
The following 3 users liked this post by rob944s2:
