Macan 2014-Current
Sponsored by: HBI Auto
Headlight adjustment
Old Jun 13, 2022 | 05:25 PM
dak911's Avatar
dak911
Default Headlight adjustment
Headlights seem aimed a bit low...is this easily adjustable?
Old Jun 14, 2022 | 10:42 AM
VAGfan's Avatar
VAGfan
Normally, you need a scan-tool to put the headlight leveling electronics into an adjustment ("basic settings") mode, before you adjust the mechanical adjustment aiming screw on the back of the headlight housing. In my experience, if you are making minor adjustments of the screw (less than 3 turns), there is no need to use a scan tool.
The headlight adjustment screws for a PDLS+ LED headlight (2019 Macan) are shown below. The small plastic "anti-tamper" plug (outer screw) must first be pried out with a very small flat-head screwdriver, to access the allen-key socket. I recall that turning the screw counterclockwise raises the headlight beam. The inner screw, without the anti-tamper plug is the Left-Right beam aiming adjustment. Using a sharpie marker, put a small dot on the white adjustment screw, so you can see how far you have adjusted it. I typically will turn the screw 1 rotation CCW, and then see if I am satisfied with the aim height of the low beam.
Old Jun 16, 2022 | 08:06 AM
dak911's Avatar
dak911
Thanks bigly
Old Jan 10, 2023 | 01:54 PM
BMinSFL's Avatar
BMinSFL
I recently had the right headlamp replaced under warranty and the dealer released the car without proper alignment. Is this something that I can adjust with the above steps or would it require adjustment that would damage or throw the PDLS+ system out of spec? That's about a 20 ft. distance.
A scan tool was mentioned in the post above. Is there something other than the full PIWIS 3 that can be used for this adjustment mode? I am happy to use this as an opportunity to invest in a good scan tool that's reasonable (<$1,000).
Thanks!
Old May 16, 2023 | 08:23 PM
bretttlang's Avatar
bretttlang
2nd Gear
For the Left/Right adjustment, does turning the screw CCW aim the headlight more towards the middle of the car?
Old May 18, 2023 | 06:00 PM
VAGfan's Avatar
VAGfan
Try it...first put a small dot on the screw, with a sharpie, so that you can return the screw to its original position.
Old May 18, 2023 | 06:15 PM
bretttlang's Avatar
bretttlang
2nd Gear
I asked at the dealership and they tell me this is standard for a German car to have the drivers side lower for oncoming drivers and the passenger side higher to illuminate signs, but I've never experienced such a prominent dip.
I used the dot method this morning and adjusted the left/right but i haven't been able to get rid of this V on the drivers side.
Old May 18, 2023 | 06:47 PM
ilovemaui's Avatar
ilovemaui
I believe the V is to reduce the light into the incoming vehicle as not to blind them.
Old May 19, 2023 | 09:49 PM
jbx2's Avatar
jbx2
That's the cut off line = normal
