iPhone volume goes to max - help
Apologies if this has been discussed elsewhere...my 2018 base Macan sets my iPhone ringer volume to maximum every time it is connected via bluetooth. I have to manually lower it but then when I operate the phone again in any way, the volume goes back to maximum. I’ve searched for iPhone related issues but it didn’t do that in my Spyder and doesn’t in other cars. If anyone has any advice, I’d appreciate it.
My F150 used to do this with my iPhone a while back, it was fixed in iOS 13. I know not much help, but just another data point. What IOS are you running?
This is not the OP, but wwahl. I am running IOS 14.3 so maybe that is his problem of an older operating system on his phone?
I have the same issue, I am running the most recent OS and my Macan always turns volume to max. It is painful, have not found any setting to change this. Using ApplePlay seems to avoid it. Would love another solution
Had this issue in my Raptor as well. Try Settings-->Sound & Haptics-->switch off "Change with buttons"
