Dustless brake pads
I took delivery of my custom ordered 2018 Macan Turbo in late 2017. It now has 6600 miles. btw no sunroof!
I have always put low dust brake pads on my high end vehicles but the Turbo has presented a problem. Front pads are readily available (Hawk, Akebono, etc) but the rear calipers seem to be unique to the Turbo-360mm. I can’t seem to find low dust rear pads. Any ideas would be appreciated.
I do not own a Turbo (I don't even own a Macan, yet), so I can't confirm proper part numbers based on experience, but TireRack shows 350mm (not 360mm) rears, and lists Akebono, Hawk, and Centric ceramic (low dust) options.
I just ordered a set of Hawk Ceramic Pads for my rear Turbo brakes from CARiD. Apparently they spoke directly with Hawk and confirmed the fit.
For $120 plus shipping it is worth the experiment.
Awesome. Could you reply back with your thoughts on the pads after you've driven the car for a bit? I plan to switch my GTS to a low-dust pad soon after it gets here.
Unfortunately I won’t be able to install the new rear pads until spring. I use my Jeep (winter beater)during the harsh New England winters.
I have always been pleased with Hawk and Akebono low dust pads.
REPORT BACK TO US IN THE SPRING.
I'll try and do the same.
I ran Hawk Ceramic low dust pads on my 997 Turbo - they’re perfectly useable on the road and last a long time. If you get them too hot they’ll start to eat your rotors, but I doubt a Macan or 911 will ever get to that point on the road (I tried them out for a track day, did not do it again...).
