Gen 1 Turbo grille screens
PSA. Ordered Weds, rec’d Fed Ex today from UK. No bumper removal, intercooler sides and lower radiator set. There is a 15% off coupon that worked. Pricey anyway but should stop any missiles.
ZUNSPORT has a 20% off ad in PCA PANORAMA this month. Expecting mine tomorrow, FedEx and God willing!
p.s: Just arrived at 6:00 p.m. Looks great!
Just finished installation this morning. Took about 45 minutes total. Excellent, logical, step-by-step instructions with good pictures. I needed to make some minor adjustments of the outer tabs of the center grilles on each side using a pair of pliers but that was it. Use masking or painter's tape as suggested to avoid scratching paint. Installed, they look great and undoubtedly will offer excellent protection. So nice to see an excellent quality product...and not made in China!
Where's the pictures?
Go to their web-site for pics and video. https://www.zunsport.com/en/porsche-grilles&filter=394 I'll post some next time we get it out of the garage.
Thank you.
Zunsports
Ok. Installed. Read instructions for the 3 piece intercooler side grilles—install center, top then bottom. I also did lower radiator grille. Easy Peazy But: center grilles a bit finicky—no external side “clips”—only a “tension” bar and no tab/hole/insert under/into which the wing ca be inserted (that I could locate with fingers, flashlight and extension mirror.With a modicum of pressure, the centers can be dislodged inwards—at least retrievable vs. losing.
Any chance we can get some more pics? Please...
Center Zunsport turbo/GTS intercooler grilles
TYVM NC Trackrat.....just reinstalled. The “outside” facing “forearm” needs bending outward then the “arm” towards the front (towards you) to finagle into the slot. Now sturdy as top and bottom. Surprised because all other clips “right on” without adjustment.
NC TRACKRAT (12-02-2020)
Promised a pic of the ZUNSPORT grilles so took this while out shopping this afternoon. Really like these!
Here's a closer look taken in our driveway:
