Macan 2014-Current
Sponsored by: HBI Auto
Coolant Leak
Old Feb 5, 2025 | 10:13 PM
  #31
TET GT3's Avatar
TET GT3
Originally Posted by NC TRACKRAT
Can you share the source for the straight hose fitting to the vent valve? Also, interested in parting with a pair of your AL fittings? PM me if you prefer.
Just found them on Amazon. 1/4" 6mm to 5/16" 7.89mm quick release connector to hose barb fitting. PM me for a pair of cnc aluminum fittings with o-rings.
Old Feb 6, 2025 | 11:56 AM
  #32
YarbSnake's Avatar
YarbSnake
Thanks for sharing guys. I’m experiencing this issue right now on my Macan gts. I’m in SoCal too OC to be exact. Anyway I could acquire a set of your fabrications? I’d gladly come to you asap.
Old Feb 6, 2025 | 04:45 PM
  #33
Santirx's Avatar
Santirx
Deleted
Old Feb 6, 2025 | 05:21 PM
  #34
quallzone's Avatar
quallzone
Several years (decades) ago, on an old Volvo "brickboard" forum, members used to suggest proactively replacing/upgrading several engine pvc hoses to silicon lines on their sedans and wagons. A few companies even offered packaged silicon hose kits for DIYers. Besides this coolant line that is a common failure point, are there any other hoses that you feel would be a good idea to proactively replace on an older or high-mileage Macan?
Old Feb 11, 2025 | 10:37 PM
  #35
Vroooooom's Avatar
Vroooooom
wow, beautiful part. looks really well made.
Old Feb 12, 2025 | 12:46 PM
  #36
TET GT3's Avatar
TET GT3
Thanks, they're working great! After digging into the engine bay to perform this repair, I'm now concerned about the various similar plastic hoses and fittings that are likely to fail at the most inconvenient time.
Old Feb 19, 2025 | 03:46 PM
  #37
Catchmybomb's Avatar
Catchmybomb
3rd Gear
Default Fittings where to purchase them?
Originally Posted by TET GT3
Nice work, we're thinking along the same lines. Not a lot of room down there and the fittings come out quite thin, so I had the fittings machined from 7075 aluminum for additional strength over typical 6061.
The plastic parts are cheap and light, which makes sense why they're used on modern cars. But not good for long term durability, so this "upgrade" should be trouble free for the life of the car.
Last piece of the puzzle was obtaining an OEM type fitting for the bleed valve, to replace the original 90 degree piece since the hose now come from the front.
where could I ordered these fittings?
Old Feb 19, 2025 | 04:12 PM
  #38
TET GT3's Avatar
TET GT3
I still have a pair if you need them. Send me a PM.
Old Feb 19, 2025 | 07:25 PM
  #39
Catchmybomb
3rd Gear
Default Contact
Since I am new to the site I cannot get your contact info until have posted a few times.
Old Jun 23, 2025 | 01:56 PM
  #40
Santirx's Avatar
Santirx
An even EASIER solution!! Installing the RADHAUS Coolant Vent Bypass hose in 1st GEN Macan
Just to clarify, even though Radhaus is using my fitting design (which is mainly a copy of the OEM design), and I built/tested a prototype, I decided to give away the design to Radhaus for commercialization. I’m not receiving any royalties, etc… my decision. Just wanted to clarify as is not my intention to promote this product here. I’m just relating my experience (successful so far).
Old Jun 23, 2025 | 02:10 PM
  #41
Van Larson's Avatar
Van Larson
Default Leak
Good work as always Raul—
Old Oct 6, 2025 | 01:54 PM
  #42
T-Rex06's Avatar
T-Rex06
I bought the Radhaus coolant bypass kit and planning to do DIY as a preventative maintenance. I also have a vacuum coolant filler kit. My question is, is it ok if I pressurize the system to refill the coolant that I've lost during the replacement? Thanks
Old Oct 7, 2025 | 07:48 PM
  #43
secondchris's Avatar
secondchris
Six months after getting a new waterpump, I have another coolant issue. From the evidence of dried coolant, I have a coolant leak at the radiator area on the Driver Side. Not sure if it's the radiator itself or something nearby.
I think this is unrelated to the topic discussed here, so sorry in advance since the title is just Coolant Leak. I will look for the correct topic. Thanks.
