18" Macan Wheels: what are they worth ?!
Hey Guys, just wanted to get an opinion on what these wheels are worth ? Two of the wheels do have curb rash, not bad at all. Overall they are mostly in really good condition, straight and true without issue.
I am located in Canada and will probably make an attempt to sell these wheels. I will remove the tires off of them, thoroughly clean them up, and move them.
Located in Northern Ontario Canada
Most Porsche base wheels are worth about $800-$1,000 / set but that's partly because they fit so many different Porsche models that all have the same 5x130 bolt pattern. The Macan uses an Audi pattern that's 5x112 so doesn't cross over to non-Macan Porsches. With 2 of them curbed, I'd say $500-$600. Maybe list them for $1,000 and take anything around $600 or better.
Northern Ontario, and they have winter tires on them. Suck it up. They are winter tires and wheels. Some tough love here. Maybe some new center caps, if that corrosion sets off you OCD.
Are you running summer wheels and tires. If not, go buy some pretty new shoes for your ride for the summer season.
I wouldn't go bigger than 20's.They are fairly priced. 21's and 22's get $illy.
If your trading your winter and summer rubber on the same rim. That is 150 per season x twice a year, x 5 years. $1500 dollars in labour.
That is the cost of another set of rims.
How far north is Northern Ontario? like Barrie? Sudbury, Timmins or Fort Severn?
An 18" BBS would be great if you already have 18" summer rubber? Depending on your roads...
