New Macan Turbo owner
Traded my Panamera Turbo on a low miles CPO MTT. Having fun with it.
After having had CTT and PTT daily drivers, the MTT seems less planted, and has a slight wander. Also the brakes are less progressive. Finally, the 'Hold' function seems at a minimum unnecessary for a sports car, and perhaps more of a problem than a help as it seems to grab at low speeds.
Anyone else have similar experience? esp about the slight wander. Not a great on center feel, as compared to the Cayenne Turbo. Quick grab on the brakes?
Otherwise it's a fun car. Definitely a sleeper.
Congrats! I just picked up a Turbo myself, and noticed the same on the brakes. I'll be swapping over to a PCCB setup in the next few weeks, so hopefully this will give them a bit better feel.
I haven't noticed much wandering, but I had the dealer lower it 25mm via PIWIS and realign everything so mine feels pretty good.
Did lowering it disable the high setting function on the air suspension? Also, PCCB wow! that's a spendy upgrade aftersale..
If the air suspension function remains intact with the low setting down 25mm I think that will be in my future.
For brakes, I found a set of take off PCCBs. Not free, but not the crazy ~$25k Porsche wants for a retrofit.
The low, normal, and high levels all still work...each is now just 25mm lower. I originally asked them to do 10-15mm (GTS-ish height) but the alignment worked out better a slightly lower level. I'm pretty happy, and all the staff there thought it looked awesome. This is pretty much the exact height mine is now. https://rennlist.com/forums/porsche-...ealership.html
Well that sounds like a no brainer. I'll have it done at the next service. I should add that while the MTT handles much better than it has any right to, my CTT didn't lean as much. I anticipate lowering it will help that some.
I’m coming from an F80 M3, so I’m trying to get a few things dialed in. Cobb stage 1, intakes, upgraded diverter valves, and lowering done so far. Remus exhaust gets installed on Thurs, and PCCB hopefully around the first week of October (waiting for a new brake booster to come from Germany). I’m also considering doing a custom BGB to help cope with the altitude in Denver and smooth out some of the roughness of the Cobb.
These are great little cars, and with a few additions can be really awesome.
You probably want to check with them first, as you want a tech who has done it before (on some Porsche car), as it’s not quite like doing an oil change. I think it was an hour of labor for the coding + an alignment for me. Maybe $500 all in?
Is your car still under warranty? I ask per the Cobb tune.
I had GIAC tune on my panny, with Innotech valvetronic exhaust. Prolly wait to tune it until it's out of warranty.
Draper, sounds like you have an awesome dealer.
I too had 2 CTTs prior to getting a Macan. My last CTT had the optional PDCC which made it corner very flat, virtually no body roll. However my M GTS corners comparably. Did your CTT have PDCC?
Also the slight wander you mention doesn't sound normal. I never experienced this with any Macan, including two long term loaners I had during CTT service visits and now the one I own. I'd certainly mention that to the dealer and have them check it out.
My CTT did indeed have PDCC; from time to time I would drive it in the canyon at 9/10ths always completely amazed at how unruffled and planted it was.
My Macan has an odd little wander, as if it were being buffeted by gusts. I'm having the car lowered next week and will have it aligned at that time, hopefully it will result in a more stable on center feel.
agree our Macan turbo has no wander. As to brakes, the Macan has rear sliding caliper so it does not feel the same as cars with multi piston calipers on front and back. Also found the stock pad compound is not that aggressive.
We we just ordered a 2020 with the PCCB but I believe the rear caliper is still the same type.
A little bit of "wander" is what made me look into proper tire pressure (I have another thread about that) - when the front tires are low (seasons change and it gets cooler) our Macan seems to want to follow the ruts in the road a bit more. Check the tire pressure?
Another possibility is Lane Keep Assist (LKA) if you have it, it moves the car around a bit to keep you in the lane and if the lane markings are unclear it can get confused. You'll feel that in the steering wheel though, not really similar to wind gust (and if you are coming from a Panamera or Cayenne it's possible you've had that option and know what it feels like already).
