I would ask why one would give up on the electronic adapting of the stock shocks. If my racing bracket allowed, I'd only consider aftermarket shocks that retained the adaptive intelligence... The only ones I know of are the DSC Sport Tractive DDA shocks. Much more tuneable by the map than two ***** to twiddle...
I have DSC on my car and honestly I don't have any understeer coupled with the TPC toe links, spacers and a good alignment. Tires are a different story but with my current setup they are holding OK....as for adjustability, the DSC module is user configurable if you want to dive into fine tuning your setup or you could add their shocks and be done with it.
The Club Sport has passives (I'm going on this on your post as personally haven't checked this) because it's a no-compromise car for the track....you do a setup for X track and you just do fine adjustments to it. A regular GT4 is a street car with very high track levels of performance so you need to please a very large customer base with different situations/uses. Ohlins is a very good setup and the reputation is excellent, but I would reserve this for a car used exclusively on the track or a car with a non-PASM suspension. Most people have a hard time adjusting single-adjustable shocks never mention double or triple adjustable!
I dont see anything about cancellation device for the stock electronic damping. I know on my KW Clubsports they came with a small box to cancel the electronic damping. These Ohlins also dont come with springs
Ohlins do a PASM delete unit and a choice of springs, not sure why the posts are so negative , Ohlins are class leaders.
Hey...I agree totally with you on this...it's just that it's a mod that most wont do because of the things you will loose on the process by taking out PASM. It's a personal choice but I think everyone is clear that this setup is a great choice if you plan to go that route.
people have spent >$10k on making the car faster which act does not make the car faster and for 1/2 that amount you could fit these and really go faster lol
we still have ZERO data for tuned 420bhp cars, they just don't go any faster !!! (yes you get midrange but if you are DRIVING the car one is above midrange !!
I would take these over $10k of bolt on engine mods and all the hassle that brings to engine warranty.
I also think spending >$2k on DSC and a full spring set is 1/2 way to buying these.
what do you loose taking out PASM ? it's flawed as is, you only gain every where fitting a plush set of passives imo, and only have two clear adjusters makes life very easy for a wet track, dry track and road set up. If I did not have the new GT3 on order this would be my 2nd mod after adjustable rear toe lings.
If you are using your car primarily as a track car, then these are an option versus other adjustable shocks available. What I don't like is the external canister and ***** being attached to the shock, as it is more difficult to access to make adjustments, versus a loose canister that can be mounted inside the car or front boot to allow easier access for adjustments.
Otherwise we all know that Ohlins makes excellent products. So I am sure these would be a good alternative to other track shocks.
For the street/track car DSC seems to be a pretty good option for those who want to keep their car closer to stock.
Good thing is this is one more good option for us to consider. Great thing about GT4 is it has gotten a lot of focus from the aftermarket suppliers for all kinds of goodies.
I fitted a set of Ohlins Road and Track dampers and springs on my BMW 1M Coupe and was happy with them, but they did not provide a tremendous improvement to the car's handling. The improvement was more subtle than I had expected. That said, the OEM suspension on the 1M was very stiff to begin with, unlike the GT4, which is softly sprung.
Separately, the marketing materials from Ohlins state that the kit lowers the car by 20 mm. I understand that the kit allows for ride height adjustment, but I am wondering whether 20 mm is the minumum drop. Given how low the car sits at the standard ride height, I would be reluctant to lower it at all.
