Brey Krause R-1046 Harness Mount Truss
#46
The belts would have to make a 90 twist, or you'd have to twist the B23B bracket a bit (which it's designed for anyway).
So you'd leave the B23B poking out through the carpet, and just clip on at the track? I figure I have to leave my side belts attached to the seat anyway, so might as well leave the shoulders attached and connect them all to each other behind the seat for driving between track days.
#47
#48
Originally Posted by Mech33
Cool idea, I don't see why not. The B23B has a 1/2" bolt connection on one side which should be compatible with the BK unit.
#49
I finally got around to cutting the appropriate slots in the carpet to put the interior back together. I think the final result is nice and stealth.
#50
Great looking install.
#51
Great job Marty
#53
Thanks guys! Looking forward to trying it out (again) this weekend at Laguna Seca. Last time I had to run with the carpet removed, so it should be a little quieter this time.
#54
#55
It looks like the shoulder harness belts are reversed.
#59
