Sponsored by: APR
strut tower failure
Old 03-12-2019, 05:06 PM
  #766
James88
James88's Avatar
Originally Posted by G-forceTarga4S
If you read through the entire post, & count them it's < 10. For the # of these cars on the road it's peanuts. Some members have had big impacts & not had this happen, so it might relate to repeated stresses & metal fatigue on a cast part.
Exactly !! Some people just love to jump on the scare mongering boat, to them it helps justify why they they dont have one or cant get one, it's really quite sad.
Meanwhile we're all having a blast owning one of the best cars that Porsche has ever produced.
Old 03-12-2019, 05:37 PM
  #767
MVEED3
MVEED3's Avatar
The concern is justified when the failure mode is catastrophic regardless of occurrence. This is especially the case in the designed area of operation. We are encouraged to enjoy Porsche's GT product on the race track and in the canyons. This real issue tips the risk factor scales away from what most of us bought the car for.
I'm attempting to find a solution to the problem and applaud our peers doing the same. It's just a tougher nut to crack than coolant lines, rod bearings, or the like.
Old 03-12-2019, 06:23 PM
  #768
hf1
hf1's Avatar
Received 1,640 Likes on 1,122 Posts
Just two Boeing 737 Max 8 have crashed so far, out of how many flying? People just panicking for no reason...
  #769
stout
stout's Avatar
Received 1,320 Likes on 613 Posts
Originally Posted by cmosman
It has probably been said before, but just to re-iterate: The strut tower plates are motorsports parts (.8A revision), the one on the right is from the cup-991's and the one on the left from the clubsport-981. in the street car, they attach to the side of the strut tower, just above the wheel well liner (which needs to be removed for access). The installation requires 58.5mm long bushings/washers as seen in the pictures. These won't be under load, so can be cut off e.g. aluminum. On the left, the mounting hole originally holds the washer fluid neck. If all should remain close to stock, attach the washer fluid neck to the bushing.
I have had this installed for more than a year, initially for piece of mind, later with the understanding of increased safety in the (hopefully not) event.
Looking at this modification, one begins to wonder if there isn't a way to create a "bucket" that fits over the strut top and bolts in much like what is seen here but without the spacer? It obviously couldn't go all the way around, and I am not sure if additional anchor points could be found (or added?) but I'd be pretty interested.
Old 03-13-2019, 12:10 PM
  #770
MidEngineRules
MidEngineRules's Avatar
Would adjusting the front sway bar to the softest setting potentially relieve some stress? (street driven cars)
Old 03-13-2019, 01:00 PM
  #771
Auto_Werks 3.6
Quit Smokin'
Auto_Werks 3.6's Avatar
That would be the opposite direction. The damage is coming from bottoming out. a stiffer sway bar will transmit some force to the unloaded wheel, or if both wheels hit the same bump it wont matter except for the friction in the sway bar. Either way, it's not likely to make a huge difference.
Old 03-14-2019, 03:31 PM
  #772
HelpMeHelpU
HelpMeHelpU's Avatar
Hope it's not a repeat already posted but this on a GT3 RS:
Old 03-14-2019, 07:29 PM
  #773
switchface
switchface's Avatar
Are these only happening on the passenger side? I'm probably wrong, but just going by memory, I want to say all instances I've seen are passenger side.
Old 03-14-2019, 07:30 PM
  #774
venom51
venom51's Avatar
Well some of them aren't panicking for no reason. I suspect anyone on the planes that were falling out of the sky had plenty of reason to panic.
Old 03-14-2019, 07:39 PM
  #775
BioBanker
BioBanker's Avatar
This talk of strut tower failures certainly has accelerated since word of a recall on the transmission came out.
I wonder what the next panic will be once the strut towers are figured out?
Old 03-14-2019, 07:48 PM
  #776
G-forceGT4
G-forceGT4's Avatar
It was never my intention to minimize or dismiss these failures as one off's or incredibly rare or uncommon.
My interest is on what can done to prevent it, especially when Porsche has claimed it's not a design problem, b/c in the end it's our cars & we pay the bills, drive them, etc
Old 03-14-2019, 08:13 PM
  #777
hf1
hf1's Avatar
I thought my sarcasm was self-evident, especially with the wink thrown in.
Old 03-15-2019, 06:27 AM
  #778
Yellow Submarine
Yellow Submarine's Avatar
You had me fooled with attempting sarcasm. But with currently only 376 in use according to Wikipedia and 2 crashes in 6 months I'd say something is not right... With 5,000 or so ordered that could mean 50 crashes every year...
Old 03-15-2019, 10:30 AM
  #779
MVEED3
MVEED3's Avatar
All 737 MAX8/9 have been grounded worldwide pending investigation of the last crash. And now, back to our regularly scheduled programming
Old 03-15-2019, 11:41 AM
  #780
okie981
okie981's Avatar
Location: On a pygmy pony over by the dental floss bush
...My interest is on what can done to prevent it, especially when Porsche has claimed it's not a design problem...
If this isn't a design problem, it's a manufacturing/quality problem, and regardless of the cause of the problem, Porsche is responsible for these failures occurring, not the owners/drivers of the cars.
Quick Reply: strut tower failure
