GT4 Sport Mode
So I was talking with my liaison at PEC Atlanta while doing laps on the track and he mentioned that, in addition to activating automatic rev matching and additional cooling, Sport Mode also "dumps a little more fuel into the injectors".
I didn't get a chance to follow-up with him on this, but I have his contact information and can reach out. Has anybody else heard this?
-Jason
-Jason
If he really means changing the injector rate, or some other fuel parameter (A/F ratio) then Sport mode is the same as a different map. Since this is the first time a different map has been associated with Sport mode in the GT4 (not uncommon with other Porsche models) I am skeptical.
Perhaps true. One thing is for sure : when Sport Mode is activated you get far more pops and burbles on the overrun. That's usually done by dumping more fuel...
Holy Guru
Registered Pontiff
Registered Pontiff
He's talking about the sport exhaust button. That's how you get the pops, crackles and burbles. This was discussed elsewhere on these forums.
It's interesting. I've recently watched a review on the new 718 Boxster with a manual transmission. The guy was saying that if you're in Sport Mode but disable the traction control,the car won't rev match for you anymore. Has anyone tried this scenario? I doubt it's true in GT4's case,but it's worth mentioning...
A friend with GT4 who is a talented racer is annoyed by the rev-match feature also. But this is his beef: the auto blip engages when you select the next gear--as you enter the gear gate. But he rev matches when he leaves the previous gear-as he enters the neutral slot. Hence his match is a fraction of a second before the auto blip match--thus causing a real problem for him.
As for me, I never learned to rev match, so auto blip is just plain cool...
*In case someone in concerned that non-use of the Sport button might lead to overheating on the track, I doubt this will ever be an issue. The car will open all thermostats as soon as it's required in order to keep temps in the normal range.
No, it's not, if you're just driving around town then it's better to run at the temperature with Sport off because thats the temperature the engine is designed to run at. If it was better to run the car at the lower temperature when driving around town then thats what it would run at.
Turning it on just forces the thermostat open earlier because it thinks that you're going to start driving the car hard, start actually driving the car hard and the car will do the exact same thing. This is why calling it 'additional cooling' is absolutely wrong, what it's best described as is 'running the engine outside the optimum temperature range for no good reason'.
