Sponsored by: APR
Crazy Dunlop tire wear
Old 05-12-2016 | 05:27 PM
Inrev's Avatar
Inrev
Thumbs down Crazy Dunlop tire wear
After one track day at Tremblant this is my front right side:
So far so good. This is my front left side:
So it seems the middle just chunked right out. I had this happen after 1 day at Calabogie last year and put it on account that Calabogie is a tire destroying track, but the same happened to me with 2 new front tires at Tremblant yesterday. So I'll be switching to a new brand as I don't think they wear out very well.
Can anyone tell me what I may be doing wrong? I ran tires at 32psi hot all around with some peaks. They are sticky tires but I can't kill a tire every track day!
Old 05-12-2016 | 05:36 PM
Jenner's Avatar
Jenner
What are your camber and sway bar settings in the front?
Based on the tread I can see on the inside of your driver side it looks like you need more a lot camber and try 30psi hot on that side.
Suggest putting street tires on your stock 20" wheels and going to 19" wheels with Bridgestone RE-71R tires. Tire cost will be lower over time (will essentially pay for the 19" rims after a few sets) and the RE-71Rs grip as well or better and last longer. I what I am suggesting myself, and if you search many others on here did as well.
But get more camber as well!
Old 05-12-2016 | 05:38 PM
Inrev's Avatar
Inrev
Thanks, running -1.4 neg camber on both sides for now with minimal toe in.
I'm also going to 19in wheels with RE71Rs. That should make track days more cost-effective.
Old 05-12-2016 | 05:40 PM
Jenner's Avatar
Jenner
I ran -2.1 camber on my dunlops at lime rock and my wear is similar but not as bad as I didn't chunk/lose the middle rib. I've also got the front sway bar on soft and toe out in the front with toe in on the rear.
I ran ~30psi hot on that tire and ~31-32 on the passenger side. After 3 track days I swapped the passenger side tire to the driver side to balance out the wear.
Old 05-12-2016 | 06:24 PM
usctrojanGT3's Avatar
usctrojanGT3
You need -2.5 or more camber to track the car and stiffer springs. When with -3.2 camber I was getting big outside tire wear...going to stiffer front springs solved that problem.
Old 05-12-2016 | 06:31 PM
orthojoe's Avatar
orthojoe
Yup. That is what happens with the dunlops. Same thing happened to me with the gt3, and that was with a track alignment.
Old 05-12-2016 | 06:32 PM
GrantG's Avatar
GrantG
That is typical on the Dunlops, particularly common if pressure is too high. I think ~28psi front (~30psi rear) hot helps with this...
Old 05-12-2016 | 07:05 PM
LaSource's Avatar
LaSource
I had not too dissimilar tyre wear with Cup 2 tyres. As someone posted earlier, the car needs more camber for track use....plus being mid engined I guess it has more weight on the front than one is used to if coming from a 911.
Old 05-12-2016 | 09:32 PM
Inrev's Avatar
Inrev
Do you guys think sway bar setting would have an impact? Right now I'm stock.
I'm running again next week and will try to get 30psi hot and see. I still have 2 viable tires left from my 2 sets.
Old 05-12-2016 | 09:52 PM
O5C4R's Avatar
O5C4R
is it possible to try not pushing the understeer through corners to save your front tyres or is this happening regardless
Old 05-12-2016 | 10:11 PM
GAZZ's Avatar
GAZZ
How long is your driving session?
Are you sliding a lot around corners?
How many sessions for the day?
Old 05-12-2016 | 10:21 PM
GrantG's Avatar
GrantG
I think pressures have more effect than alignment and swaybars for the center of the tread. I know it sounds low, but I aim for 28psi front hot and it's better. If you're headed to the same track with same tires (or another track that works the same side of the car), rotate your tires left to right (they're non-directional).
Old 05-13-2016 | 12:05 AM
Inrev's Avatar
Inrev
Originally Posted by GAZZ
How long is your driving session? Are you sliding a lot around corners? How many sessions for the day?
25 mins
No I'm fairly smooth
6 sessions
Old 05-13-2016 | 12:13 AM
O5C4R's Avatar
O5C4R
well that's concerning then, I'm doing a track day next week with these same rather expensive tyres and I really hope this doesn't happen to me
Old 05-13-2016 | 12:40 AM
Inrev's Avatar
Inrev
I think the guys are right about pressure. Don't let them get up too high. I stared high and adjusted downwards as I was afraid to kill the sidewalls if they were too soft from the get go.
Quick Reply: Crazy Dunlop tire wear
