Sponsored by: APR
Experiment - GT4 Track Setup Wiki:
Old 08-07-2021, 02:53 PM
  #556
ALE
ALE's Avatar
JWR9152 - thanks for the reply and I look forward to your review.
Old 09-03-2021, 03:05 PM
  #557
ALE
ALE's Avatar
265/35/19 & 295/30/19
If any of you have either run these sizes or specifically the new Conti/Hoosier tire, please share your feedback. As you can see in the attached chart, the rear size is a little out of tolerance.
Thank you,
Al
File Type: pdf
Old 09-03-2021, 03:45 PM
  #558
jwr9152
jwr9152's Avatar
Thank you,
Al
I've run that setup on Supercar 3s. Front end was great, but I would tend to get corner exit over steer. I switched to 305s in the rear and it suited my driving style perfectly.
Old 09-30-2021, 11:11 PM
  #559
Four Ring Circus
Four Ring Circus's Avatar
Originally Posted by ajw45
Ah, that's A good point. I've never driven with PCA but I remember hearing they won't pass you for tech if you cut the passenger side lwbs for a 6pt. Seems like a silly rule but worth checking to see if that's still a thing. Schroth does make a GT3 version of the 4pt with ASM to fit the lwbs as well so that's a great option too.
Hi all- doing my research as I watch the GT4 market (I posted on here a few weeks ago about modded Cayman S vs GT4- my Cayman was lost in Ida floods last month). One place where I have been going back and forth was buying a car with LWB and I HAD decided to look for LWB car thanks to the feedback on here. Then I came across a few posts on this sticky that says you have to cut the passenger seat for the sub belt of a 6 point harness, which may be flagged by some clubs?! What is the solution here, if that same club requires the same restraints and seats on both sides? Why the heck would Porsche design the passenger seat differently than the driver seat? What are your thoughts on the integrity of the LWB after it needs to be cut? Wondering if I should find a GT4 with sofas and put in proper race seats (which have more lateral support anyway than LWB). Can anyone confirm this about clubs flagging the seats? (I am in NJ so I have run mostly with NNJR but sometimes the NYC amd Philly clubs too). Thx!
Old 09-30-2021, 11:21 PM
  #560
m3bs
m3bs's Avatar
That makes no sense. Nor does not having the opening pre-cut on both seats, for that matter…. If indeed cutting the opening for the passenger seat is an issue with PCA that just gives me one more reason not to run with them. I’m getting mine done next week.
Old 09-30-2021, 11:47 PM
  #561
Jim Vinci
Jim Vinci's Avatar
Cut both seats. Its dont ask dont tell. Not having same belts was an issue with Niagara region but not the others.
Old 09-30-2021, 11:48 PM
  #562
Montaver
Montaver's Avatar
I run the Schroth 6 point on the left, and the specifically designed Schroth 4 point on the passenger side. Absolutely no need to cut up your LWBS, especially if you are only taking passenger occasionally. Many clubs you don't even get out of the car for tech inspection these days because of COVID. Most instructors will have no issue with it, if they do just run 3 points if you have them in the car.
Old 09-30-2021, 11:54 PM
  #563
m3bs
m3bs's Avatar
I could see taking issue with that. 4-pt is NOT equivalent to 6-pt.
Old 10-01-2021, 12:00 AM
  #564
Jim Vinci
Jim Vinci's Avatar
I do the same as Montaver and Niagara was the only region to make an issue of it. But I've ridden in the right seat with the 4pt ASM belts and dont find them as comfortable. If had to do it over again I would cut the seat. Once these belts expire I'll probably cut the seat then.
Old 10-01-2021, 12:22 AM
  #565
paffinity
paffinity's Avatar
Was that on 10.5" rear wheels? Or 11"?
Old 10-01-2021, 08:55 AM
  #566
jwr9152
jwr9152's Avatar
11
Old 10-01-2021, 10:41 AM
  #567
Montaver
Montaver's Avatar
I didn't say it was equivalent..
Old 10-01-2021, 12:40 PM
  #568
sonorous
sonorous's Avatar
I would argue the factory seats were "designed for use with safety harnesses" which is the grey area people worry about. The seat actually has the the area marked by the factory for where option the opening. I see a lot of LWB seats with six points at my events and I have personally never heard of anyone getting grief about them in any region or from any shop. Go for the 6-points and OEM seats. It is a lot safer overall and avoids race seats with 3-points on street. A whole other can of worms...
Old 10-03-2021, 10:50 PM
  #569
paffinity
paffinity's Avatar
11
Thanks. May I ask which wheels you're using?
I got the ever popular Forgeline 19x9,19x10.5, but if there's a set that can fit 11 in the rear (or even 9.5 in the front) then I'd be interested in getting for a 2nd set of track wheels.
Old 10-03-2021, 11:00 PM
  #570
jwr9152
jwr9152's Avatar
i have a set of Forgelines 19x9, 19x11 and a set OZ Leggera HLT 19x8.5, 19x11.. You do have to run spacers in the rear because I'm running 50 mm offsets. The OZ don't clear the front calipers, as well as, the Forgelines.
ZG911 (10-20-2021)
Quick Reply: Experiment - GT4 Track Setup Wiki:
