approx cost to swap out pccb?
so if you had a pccb and wanted steelies what would approx cost be to swap out? it seems that many intend to do this anyway.
and is there any value to the pccb system if you were to put them for sale?
I think you'd be better off finding aftermarket steel rotors that will fit the PCCB caliper, in fact I seem to remember reading that you can use OE steel rotors with PCCB calipers if you just remove a spacer on the front calipers intended to allow them to handle 410mm rotors, or maybe that was the only design difference but the spacer isn't removable? Anyhow, I believe the pad shape is the same between the two caliper types, so once you had a rotor solution pads would be no problem. You'd still have a different brake booster from factory steel brakes, so it might feel overboosted, but replacing that would be a lot more effort and cash.
I doubt you'd find much of a market for PCCB parts except maybe pads and (in time) rotors. For the rest, I believe Porsche sells official PCCB retrofit kits, at least for other cars.
If there is a market for PCCB retrofit I bet you'll be disappointed in what you can command versus what you think you can command.
In another words, price an earlier MY model on the used market and see what the PCCBs add in value compared to the original cost. And DON'T believe stealers.
Actually I wouldn't because I think they are totally overrated and furthermore somebody shopping usedcars isn't going to want the burden and potential cost of maintaining carbon brakes
They are a bling item for back nine bragging
I 2nd putting on steel rotors and pads. Girodiscs, PFCs, AP. Save pristine carbon rotors and pads when you sell it. Trying to swap calipers and such may be a pain... not sure if the master cylinder is different (it was in the previous gen caymans).
I'm not sure I understand this? They are not going to add the 'first cost' value to a used car so why not run them. The exception is cars that will see regular track duty.
There are basically three options (other than just ordering or buying a car with cast iron brakes):
- Drive it with the PCCB's. If or when you need to replace them, replace them with cast iron.
- Replace the PCCB rotors with cast iron. Leave the rest alone. Sell the rotors. Should be fairly easy as they fit the GT3 and turbos as well. I would guess they would bring around $15k as 4 new rotors would cost $20k.
- Replace the PCCB rotors and save them. Put them back on the car for resale. Might bring an extra couple thousand dollars.
Saving them for the next owner really makes no sense - financial or otherwise. I'd say either use them or sell them. Replacement cast iron rotors should be around $4k. A few companies already have them available.
Let me know my car only has 186 miles of usage so far so brakes are essentially new.
Even on the track, folks are getting a ton of life out of the Gen 3 PCCBs.
There is a thread in the GT3 forum that has 3 guys (iirc, at least one in Europe and one in North America) reporting how their pccb are toast after only a handful of track days. Pccb longevity has a LOT to do with the track and the DRIVER.
Perhaps the point here is that steel brakes are a known quantity.
And pccb are a known unknown for many folks. And frankly the cost of that education eclipses the value of the lesson for most applications.
the OP wasn't about the merit of one or the other.
Speaking of misinformation, are you SURE about this statement?
I would never buy/pay a premium for a car with PCCB for how I use the car. As much as people say they work for the track, there are anecdotes to say the contrary - and not to mention it's 20K for a new set - vs. 1200 for iron rings F/R with a AP/PFC setup. If you are a beginner, you're probably safe. If you are a track rat and baller enough to spend 20K (20% of the MSRP of a GT4) a season on rotors, you should have bought a cup car.
If you are going to sell the rotors on ebay or on renn, there is so much misinformation about wear that right off the bat people are skeptical of the condition and you'll maybe get 7-9K for a nearly new set.
sample set:
2014 911s pdk coupe with roughly same miles
