Anyone have a Video VBox CAN connection running in a GT4?
#61
#62
#63
Booya! Got my CAN stuff working with the help of the information here and more info from ShakeNBake. Thx!
I have the can clip on attached by the driver's side fuse box and it works; However, the cable that comes with it is then too short to reach the vbox mounted on the passenger fuse box cover. I can clip it on higher in the foot well, but I am having real trouble working upside down and getting the twisted can wires unwind enough here to slip in the clip on. Is there a trick to unwind the wires? I am afraid of breaking them if I am too rough...
Also,
How are you guys handling brake pressure in the scene? While throttle comes through as %, brake pressure is a raw measure in bar. I'd like to show it as a % in the scene similar to throttle position. One way is to just test by mashing the brake and see what pressure it gives me as a max and then use it to calculate % or just set it as the max of the range in the bar chart.
Just curious how others handle this one?
Also,
#64
Also,
Also,
#66
vbox all up and running really well.
I have mapped the left/right steering maths wrong (shows left when pointing right!) and need to swap over.
In the meantime, here is a lap of legendary Spa Francorchamps from last weekend! A couple of GoPros added for additional views
#67
Getting close to done with the VBOX scene. It's 98% accurate size wise, which is the problem, I need to scale it a bit in a cartoonish way. Gears not working properly yet....this lap had the wrong mapping to the brake...it's coming along.
#69
LaSource - great video at Spa - just wondering - your title says GT4 Clubsport, but it's a manual in the vid - is that a different option in the UK? I thought Clubsport was PDK only?
#70
Sorry, I just meant a road GT4 with the EU Clubsport spec (buckets seats, 6-point harnesses fixed to rear bulkhead, fire extinguisher, rear roll cage, cut outs for front roll cage)....I guess this option was not available state side.
#71
It's worse, they didn't even leave in the anchor points so that US owners could install parts obtained from the EU....
#72
#73
At first look I started your lap about midway and immediately thought: "WTF? Why is he left foot braking EVERYWHERE?!" before I realized your brake mapping must be wrong
#74
Definitely thinking the same thing you are with the center dial size. I'm going to play with ratio of text size and dial area to keep the look of a GT4 dash, but it will no longer be to scale.
#75
Ok some changes to the scene. Smaller dials, and truncated to removed wasted space.
Latest
Previous version
Latest
Previous version
