GT4 Oil Filter and Wrench
I did a search but did not come up with anything... In preparation for a post break-in oil change I want to buy a filter element and a tool (wrench) to remove the filter housing. What are the correct correct details or P/N for the filter and tool for a GT4?
I see that Suncoast finally lists a filter kit for $32. Is this really the best option or is there an equivalent from Mahle (which seems to be typically about half the price of OEM on Pelican Parts)? I am sure I can just pick up an element from the dealer but for the tool I would rather not pay the Porsche tax and I have not found a site that confirms what will work with the GT4.
I roughly measured the filter housing in my car with calipers and it looks to be the 74mm w/ 14 flats. A little searching showed that the Porsche size is actually 74.4 mm. From what I can find the OEM or OEM equivalent tool is the Hazet 2169.
I was thinking about trying this one: Or this one:
There are some reviews saying that it works on some Porsche cars. The construction looks decent.
Any comments or suggestions are appreciated.
Its the same as the 981CS and the same wrench. Checked with the dealer i had some left over from my 981CS. Good idea to also replace the plastic canister for an extra $20,they can crack. The assembly #9A110702400 carl
I did many oil changes on my 05 Boxster for 10 years and never once changed the canister.
Just have to be careful and not over tighten.
From age and heat the plastic gets brittle. For 20 bucks amortized over 10,000 miles why take a chance?
The thing i forgot to mention is to replace the drain plug and washer every time. Its alum with a relativity high torque spec of 37FT LB and the 8mm hex will strip over time. They are about $6 each..carl
Addict & Guru
I havent had a problem with the three 981s Ive had but on past audi's and VWs ive had leaks with the plastic canisters.
I bought a spare drain plug 9 years ago, but its never been needed. If you take care to fully seat the hex socket and properly torque it, it won't strip.
Of course, use a new crush washer and canister gasket.
I never changed the drain plug either in 10 years, really not necessary.
The only things I change along with the oil is a new oil filter,canister gasket and crush washer.
That's it.
Don't waste your money.
That's it.
I always error on the side of caution. We're talking nickels and dimes. To each his own,but to spend an extra $ 26 every 10,000 miles for a new plastic canaster and drain plug to make sure you won't have a bigger issues later seems to me like a good deal to me. Then again what do I know? Carl
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
How are you all changing the oil?
Are you using an oil extractor or simply removing the drain plug?
Does the car need to be on a lift/stands/ramps to access the filter and plug?
So I checked pricing at my local dealer and also included the plastic filter housing since you brought it up. I am not sure I will replace it every time but it sounds like a good thing to keep around to be safe. I got some interesting pricing back. It turns out you can buy the housing with filter element and seal pre-installed and it costs less than buying an OEM filter plus O-ring seal separately without the housing. Go figure? It had the parts manager scratching his head but I will go that route!
