Australian GT4s
#46
the straights won't be too long. 130km/h is plenty on the roads.
and if you are a newbie, it's a great way to learn the roads/etiquette.
i've only done track, but not any targa, as think it is very risky. touring would be a great place to start
on unfamiliar roads. all your cornering will be done at 50 - 100 anyways.
#47
Thanks for your thoughts. I have done Targa Tasmania a number of times before in Nissan GT-R. Finished in top 10 a few times and 2nd Outright once so I probably have a different perspective on things. I am sure that lots of competitors will be happy with the 130kph limit. Just struggling with the concept myself.
#49
Not a problem at all Jimmy. I hope you have a great time there. There are some straights in Targa across the top of Cethana and on Mt Arrowsmith where you can see 280-300kph if your car can do it. Can be scary. I remember thinking "what the hell am I doing here" one time on Cethana during pouring rain at 260kph and the wipers starting to lift off the windscreen. Makes you think we must be all crazy.
#50
For those that are interested I have found that Rays have the TE37 Ultra available in 11" x 20" ET 50 for the rear which is the exact factory fit. However the fronts are only available in 9" x 20" ET 45. This puts the wheel outside 22mm further out. I measured a GT4 today and I think this puts it a few mms outside the wheel arch. So it is a no go in current form. Rays would be smart to offer an 8.5" x 20" with the correct offset and they would get a lot of business. I am looking at whether the wheel can be finessed a little to make it fit.
#51
There is a lot of talk on these forums about people putting clear film on their cars. Is this a track only thing? Or a North American thing? In 20 years of car ownership I've never done this. Any of you guys planning on getting this done?
#52
Seems like we need to watch out for the headlights though because products like Xpel will delaminate the lenses when removed.
#53
Last car had it and saved a lot of damage. The side scoops will get a lot of damage from sand and small gravel chips.
Much less pulverizing on your car at the track if nobody overtakes you. -I try to never let that happen!
#54
In regards to wheels with the exchange rate where it is japan is an excellant option but I would strongly recommend tws over rays, they are more of a race team supplier as opposed to a consumer supplier, their wheels are lighter and they will do a short run with custom offsets. And, frankly, te37s are massively overrated.
#55
#56
What material are you having applied Gazz?
#57
Best wishes
Chris
#58
Hi Jimmy
#59
#60
I am investigating it. PCM have recommended an installer that uses the Premiumshield Elite product. The installer says it is better than the USA favourites of Suntek and Xpel. I have no idea so it would be good to hear from our USA friends who have actual experience with these products.
I was also looking at getting the remainder of the car treated with Opticoat Plus as well.
C
