Suggestions for Replacement Rotors
Old Sep 20, 2021 | 02:07 PM
switchface's Avatar
switchface
Question Suggestions for Replacement Rotors
I have about 41k miles on the clock. The car has been bulletproof. With that said, I noticed a lip forming on my front steel rotors, so I guess it is time for a replacement.
What are the standard recommendations and the pros/cons of each?
  • OEM
  • AP Racing J hook
  • Girodisc
  • other?
Car is mostly street driven, with a random track event once a year.
Appreciate everyone's suggestions/opinions.
Old Sep 20, 2021 | 02:34 PM
9eight7's Avatar
9eight7
  • OEM
  • AP Racing J hook
  • Girodisc
  • other?
My 2 cents...
  • OEM
    • ~$700 each front rotor
    • Street - Designed for the car and does a great job for street use.
    • Track - They wear fast, could crack between the holes, and doesn't have great feedback/feel.
  • AP Racing J hook
    • ~$850 each front rotor (hat + ring)
    • Street - They work well on street but are excessive.
    • Track - They wear slower, no holes to crack, slightly warmer than OEM (due to slots instead of holes), and have good feedback/feel.
    • These look super cool!
  • Girodisc
    • ~$800 each front rotor (hat + ring)
  • Sebro
    • ~$520 each front rotor
    • Street - They work exactly like OEM. It's a great alternative.
    • Track - They wear slower, no holes to crack, get warmer than OEM (due to no slots or holes), and have good feedback/feel.
  • Brembo
    • ~$950 each front rotor (hat + ring)
If I were using the car purely for street, I'd just go with OEM or Sebro slotted rotors.
Old Sep 20, 2021 | 04:52 PM
Montaver's Avatar
Montaver
With the aftermarket stuff its a larger upfront investment, for cheaper replacement costs down the line as you can keep the hat and just change the rotor. Girodisc and AP are battle tested in track conditions which are much more extreme than the street, and will last longer rotor for rotor as there are no holes to crack.
Old Sep 22, 2021 | 10:38 AM
Four Ring Circus's Avatar
Four Ring Circus
I didn’t realize this until I dug a little deeper into the AP brakes- the calipers they sell are lighter than OEM but more importantly have an open design that doesn’t require removal of calipers to change pads, which is a huge time saver for people who want to run an aggressive track pad and swap back to quieter pad for street driving. Of course requires purchase of calipers for even more up front cost, but good long term investment IMO.
Old Sep 22, 2021 | 05:52 PM
paffinity's Avatar
paffinity
Can the Essex rotors be used with OEM calipers?
Old Sep 22, 2021 | 07:23 PM
Tay101's Avatar
Tay101
They have rotors for the OEM calipers.
Old Sep 23, 2021 | 09:57 AM
lcjhnsn981's Avatar
lcjhnsn981
Does anyone have a source for Sebro slotted rotors in GT4 sizes?
Old Sep 23, 2021 | 02:05 PM
ShakeNBake's Avatar
ShakeNBake
I was amazed at how long AP rotors last. Night and day compared to PFC and OEM rotors. I can go at least a year on a set of front rings.
Old Sep 27, 2021 | 08:17 PM
switchface's Avatar
switchface
Originally Posted by 9eight7
My 2 cents...
Thanks for the detailed breakdown. Interesting that I have no signs of cracking whatsoever, just that I've worn away enough of the rotor to have a lip form at the edge. Has anyone else had to replace rotors due to this type of wear? I figured this would be a more common occurrence.
For those upgraded options that are 'excessive for the street', are there any street-associated drawbacks? For example, do they not get up to temp on the street or are they overly squeaky (I assume that has more to do with the pads)?
Suppose I'm in the minority, but I actually like the way the OEM drilled rotors look (although I'd place those Brembo Type 3s as a close second). I'm hesitant to get the OEM replacements given how quickly they wore. In contrast, my previous 987 had ceramics and they barely had any wear at all after 70k miles and a few seasons of auto-x.
Old Sep 27, 2021 | 08:28 PM
akhbhaat's Avatar
akhbhaat
I doubt you'll get cracks with 1-2 track days per year. It's mostly caused by aggressive heat cycles, which are a consequence of how often you're on the track and what sort of pace you run.
Took me 6-7 track days to start seeing any cracking at all (and that was just a couple <1 cm surface cracks on the front rotors), and I was running track pads (RE10) for about half of those.
I would probably go with the Sebro slotted in your case. Anything more is overkill.
Old Sep 28, 2021 | 06:48 PM
Jim Cobb's Avatar
Jim Cobb
Glad to see this thread, because I am looking at replacing all 4. If I don’t care how excessive or ugly they are for the street and am simply looking for the ones that hold up the longest under aggressive track driving, what’s my best bet? Thanks for any feedback.
Old Sep 28, 2021 | 09:07 PM
patriot993's Avatar
patriot993
Coming at this question with a Spyder versus a GT4 so your mileage may vary. Drilled rotors develop cracks on my car after a couple of days on the track, though cracks not connected and still pass tech inspection.
I moved to Sebro slotted in the front and happy so far; the rears though seem to be an odd size so haven't yet sorted out a slotted option other than Girodisc, which I don't feel like springing for yet.
Given that you are not tracking a lot I would recommend Sebro - good bang for the buck
Old Sep 28, 2021 | 10:26 PM
milrad's Avatar
milrad
PS Armorer
When I bought my car it had Giro Discs on the front already. They seem to be wearing great (I've added 5700 miles, roughly 2500 of which are track miles). I'm using RE10 pads. I'm ready for some new front pads, and while the front rotors have hardly any wear they are just starting to show some cracking. I'd buy these again in a heart beat. They work great on the track.
Old Sep 29, 2021 | 12:27 PM
9eight7's Avatar
9eight7
…For those upgraded options that are 'excessive for the street', are there any street-associated drawbacks? For example, do they not get up to temp on the street or are they overly squeaky (I assume that has more to do with the pads)?
I don’t believe any steel combination will last as long or be as clean as a ceramic setup. I can’t really speak to the drawbacks either as I haven’t driven OEM pads on any aftermarket rotor.
Changing your rotors at 40k miles is pretty good for a performance car! How many miles do you think you’ll out on your car’s lifetime? Maybe math it out and see what works to your benefit.
I haven’t had my car for very long so I don’t have direct experience, however I have several friends that do with the same use case. Most of them replaced the front rotors with either Girodisc or AP Racing paired with DS1.11 front and rear. Some are still using the OEM rotor in the rear (between 15-25k miles?). I guess the fronts do most of the braking so the rear I doesn’t wear as fast?
My car came with Brembo front/rear rotors and I’ve never driven an OEM GT4. With only 2 days so far, they seem to be better than the Sebro on my 987.2, which started to fade when I went to wider tires (245/275). That being said, the brakes on the 987.2 were engineered for skinnier tires (235/265), so the additional traction may have changed the balance (wild guess here).
Best bet, I think go with any of the track focused options in terms of longevity and performance AP, Brembo, or Giro (no particular order).
Old Jan 21, 2022 | 11:23 PM
cooler2442's Avatar
cooler2442
I'm approaching 15k miles and my front rotors are starting to lip with no track time(just canyons). Do we have any other options yet or are all of the above the only options?
