Rennlist iRacing thread
Hi All,
I signed up for trading paints last night and downloaded a skin for the Porsche.
I am no artist so i just painted this car to a different color and modified it a little.
So for the most part this is the car i will be running in the league.
It's not completely finished but i like the looks of it so far.
By the way Thanks to David ter Stal for uploading the skin to the showroom for guys like me with no talent to use.
Regards,
George (SpeedBump)
Attachment 795892
Regards,
George (SpeedBump)
Attachment 795892
Did you see the one in the forums that guy is doing of the LeMans Lizard livery? Holy hell..
http://members.iracing.com/jforum/po...t/3229613.page
Sweet!
Question for all those with the Fanatec GT3 wheel, what do you have all your setting set to?
Stupid me just plugged it in and started to use it not knowing that it has all these settings and driver. I only learned once I now have my shifter mounted I needed to calibrate it. So went through the different settings, but if you are not careful with force feedback it would probably rip you arms off :-)
Found this site with some settings: http://f-wheel.com/settings/gt3rs-v2clubsport-iracing
I have the fanatec turbo s, I set the driver to 900 degrees, the wheel is set to off, and i change the FFB/Shock depending on the car I'm driving. Also, the amount of FFB is dependent on your settings in the sim so make sure you take a look at those settings.
I just did one this morning that was a take on the Tudor partnership launch car. It was an easy one to do, not sure if I really like it or not.
Trying to decide which one to stick with (the Patron is going to a friend once he signs up for iRacing). Thinking I might try to do the Goldcrest Motorsports car (Foametix).
