Setting up Aim Solo DL and smarty cam
I have 16 GT4 street car -
What ecu do I pick?
Choices
EMs SDU 3.2 Siemens
cayman ABS M4
Cayman 981 GT4 Clubsport (this one resembles closest)
What ecu do I pick?
Choices
EMs SDU 3.2 Siemens
cayman ABS M4
Basic Site Sponsor
Basic Site Sponsor
Received 2,837 Likes
ECU Make: Porsche
IF you are connecting via OBDII cable, 991_981_OBDII
If you are connecting direct wire to the twisted pair, 991_911
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Thank you for the info peter.
For now I'm goign w obd. I just tested it w wrong ecu setting (seiman - from previous car)
This worked for everything except brake pedal pressure and no engine temp.
I will change to obd ecu and try again. I am waiting for the direct connect wire to come so I will need to run this next weekend at COTA. It will be fine. I will report back in couple hours after I make changes
Another question - I have built in ext mic attached to the harness that goes from aim solo dl to camera. I guess aim camera picks up internal as well as ext sound. I just watched the test video and There was a lot of wind sound just driving on the freeway. I placed the ext mic in the sliding storage behind pass seat. I think sound gets recorded from int mic as well. Perhaps I can put the gain down on the camera setting. Suggestions?
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
Then, create a Porsche 991_981_OBDII config with SmartyCam channels properly assigned, then "Transmit" to your Solo DL.
Then, plug in the OBDII connection to the car, turn on the key and with the laptop connected to the Solo DL, select Online in Race Studio 2 and verify brake pressure comes through when you hit the brakes. Car doesn't have to be running.
It didn't used to work, but I've heard it works now.
Thanks!
Peter - it is the latest version of RS 2 2.56.00
Reporting back w obd connection:
No brake pressure
No throttle
No engine oil temp.
Rpm, gps speed, water temp is working
I will create new profile and try again.
No brake pressure
No throttle
No engine oil temp.
Basic Site Sponsor
Basic Site Sponsor
I'm running a GT4 with AiM Solo and OBD connection. When you do the configuration, make sure to check the throttle position. There is no brake data available. The other issue I've had is getting the proper "Calculated Gear" to work. I can get Oil Temp, again, check configuration setup.
Basic Site Sponsor
Basic Site Sponsor
Gear from the ECU only comes through on PDK cars, not the street GT4.
I recommend Pedal Position, not Throttle Position (unless that doesn't work). Nannies show in Throttle Position, your actual foot and brain shows in Pedal Position.
Basic Site Sponsor
Basic Site Sponsor
The car isn't running. Fire it up and see if anything changes from ERR to reading.
Yes, this is why every GT4 setup I have sold people uses CAN. It hasn't worked before (brake pressure, fuel level and oil temp) over OBDII.
991 GT3 and GT3 RS does, though...
I have the can bus wire coming. I guessed that is the only way...
The software takes time to learn.. when u said math channels and such, i just lost u lol
Basic Site Sponsor
Basic Site Sponsor
