Current draw for MXL2 with Smartycam HD
Old 08-16-2016, 02:25 PM
kristap
kristap's Avatar
Default Current draw for MXL2 with Smartycam HD
Is there a way to calculate the current drawn or determine (without a multimeter) the current drawn by the dash and camera?
Aim specs the MXL2 draw at 1400mA ... but what happens to that number when the smartycam hd is connected via expansion hub for power?
Not trying to troubleshoot, just trying to map my power uses and needs.
Old 08-16-2016, 02:43 PM
winders
winders's Avatar
You need a multimeter or a clamp meter.......
Old 08-16-2016, 03:04 PM
amso3
amso3's Avatar
Is your data hub getting power from an external source or from the dash?
Old 08-16-2016, 05:15 PM
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Matt Romanowski's Avatar
The AiM website says the dash draws 400 mA and the SCHD Rev2 700 mA. I'm not sure, but I know it's always less than 3 amps because I have it on a 3 amp breaker and it's never blown.
Old 08-17-2016, 12:17 PM
kristap
kristap's Avatar
From the dash.
3amps sounds good - I can work with that.
This is for a new build - I would like to see if I couldn't make a pdm15 work
Old 08-17-2016, 12:27 PM
gobuffs
gobuffs's Avatar
Originally Posted by kristap
This is for a new build- I would like to see if I couldn't make a pdm15 work
Old 08-17-2016, 12:30 PM
ProCoach
Basic Site Sponsor
ProCoach's Avatar
Received 3,270 Likes on 1,865 Posts
I'll only add that when running multiple cameras, particularly the limited capacity battery equipped GP models, I have found it necessary to add a diode equipped supplementary power cable to one of the open ports on the Data Hub to maintain the batteries in multiple cameras.
The issue is not the dash draw, it's the charging draw for the batteries, particularly when low after longer layoffs between events. The current capacity through ONLY the AiM CAN is limited, and the supplemental switched power supply of either the additional diode equipped power lead OR a two port powered Data Hub may be required.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Old 08-17-2016, 09:28 PM
amso3
amso3's Avatar
I agree with Peter that is why I asked whether you had external power to the DH. I like using the external power Data Hub when power draw (or charging the GP battery) is an issue
Old 08-18-2016, 10:23 AM
kristap
kristap's Avatar
Ah, not a DH but rather channel expansion - I typed expansion hub but meant channel expansion.
Fair to say that the dash with sensors & channel expansion plus a single smarty cam would be sufficient on a 3a circuit and definitely fit within an 8a?
Old 08-18-2016, 11:45 AM
ProCoach
Basic Site Sponsor
ProCoach's Avatar
Absolutely!
Old 08-18-2016, 11:52 AM
gobuffs
gobuffs's Avatar
I forget exactly...but I thought you couldn't have a channel expansion and the smarty can hooked up to the dash? I have that but forget how I hooked it up. I have the dash, smarty, DH and 2 channel expansion. The DH is full.
Old 08-18-2016, 02:07 PM
Matt Romanowski
Rennlist Hoonigan
You can do the SCHD and channel expansion, you just need a data hub. You can daisy chain data hubs together to get more inputs.
The dash only has a single expansion plug.
Old 08-18-2016, 02:52 PM
ProCoach
Basic Site Sponsor
ProCoach's Avatar
Yep.
Data Hub lead to single AiM CAN connection at dash.
Antenna (five pin, for dashes), SmartyCam and 2 Channel Expansions into four open ports on Data Hub.
Old 08-19-2016, 11:22 AM
kristap
kristap's Avatar
What they said I needed the expansion/data hub because the dash wouldn't support both the SmartyCam and a GPS. For some reason that I can't remember top of my head, I couldn't daisychain the GPS to the SCHD to the MXL2.
edit: just remembered - LCU-one lambda controller.
This but with a SCHD and only one controller...
Old 08-19-2016, 06:17 PM
ProCoach
Basic Site Sponsor
ProCoach's Avatar
The GPS-05 and GPS-08 antennas that come with the dashes are five-pin AiM CAN enabled. They plug into Data Hubs that allow daisy chaining of additional AiM CAN accessories, like LCU-Ones, Channel Expansions, Thermocouple Expansions and SmartyCams.
The GPS-05B and GPS-08B antennas that go to the SmartyCams (of all years) are four-pin SmartyCam only.
Quick Reply: Current draw for MXL2 with Smartycam HD
