I got my Vbox HD2 installation completed yesterday on my GT4. It looks great: mounted on the firewall behind the driver’s seat and all the cables tucked neatly away. More info and pictures to come on that. GT Auto Concepts in the Bay Area did a fantastic job and I couldn’t recommend them more highly.
I’ve got a basic scene file working, using the .ref file from Racelogic, that includes brake, RPM and throttle position, all from CAN. However, showing steering is proving to be tricky.
On the GT4, the steering angle CAN channel doesn’t include information about whether the wheel is being turned left or right - it’s just the angle off the centerline. 0 is center and 470 is full-lock left or full-lock right. There’s another channel - steering direction - that shows whether the wheel is being turned left or right. 1 is left and 0 is right.
I’ve used the Maths Channel feature to combine the two channels into two new channels: one for left and one for right. Here’s the formula:
Right turn
-StrWhlAngle*(StrWhlDirection-1)
Left turn
StrWhlAngle*StrWhlDirection
I’ve got the new channels assigned to a left turn and a right turn horizontal bar. Each gauge uses the same scale: 0 to 470. The left turn bar extends from the right to the left; the right turn bar does the opposite. Here’s what it looks like in the Vbox Video app:
Unfortunately, it’s not working correctly. The right turn bar works but the left doesn’t. It’s filled (as if I’m doing a hard left turn) when the wheel is in the center or when the wheel is turned to the right. The bar then starts going down as the left turn angle increases. It’s weird: I’ve tried all the other combinations of the left bar (e.g., filling left to right, starting at the left) and they work but given the design, the only bar setup that makes sense for showing a left turn is one that goes from right to left, with the minimum value (i.e,. wheel centered) on the right. Here’s a video of Circuit Tools that shows the problem. The graphs on the bottom show the output of the maths channels I created. You can see that the left turn bar isn't working correctly
I do have a support ticket open with Racelogic but while I wait to get it figured out, I’m wondering what other Vbox users do for steering angle. I was thinking of not bothering trying to show steering direction and just showing a vertical bar mapped to steering angle. The second camera shows my hands, so I don't really need the bar to show the angle. However, now I've got my mind set on figuring it out! I know the GT4 uses two channels for steering; perhaps other cars do too and people have got a solution.
Right turn
Left turn
Thanks!
You can see my steer input bar on the bottom left, the number in white is the steering angle.
__________________ -Peter Krause www.peterkrause.net www.gofasternow.com
