Sample vbo files for building scene?
Basic Site Sponsor
Basic Site Sponsor
Received 3,270 Likes
I'm hoping for operator error, that's for sure. For now, I am just using a vertical bar that shows steering angle but doesn't show direction. Since the second camera shows direction, that's fine but it would be nice to have lateral bars working. Any chance you can connect me with someone who's got it working? I don't think ShakeNBake's scene file has steering angle; or does it?
I haven't done the bars yet myself because in the rare occasions that I use a scene with steering angle, I prefer a steering wheel icon, sometimes with a numerical value in addition.
IMO, the steering angle element value is limited because it's so easy to diagnose steering speed and amplitude driver control deficits with the second camera. To me, that is the value of the second camera. The ability to compare steering angle at the same GPS coordinates, along with track position in the side by side video is KEY!
All of the standard caveats apply. More than one input per given radius is not good, particularly adding. Steering wheel input rate of change should not be the same according to vehicle speed and corner radius (the old slow corners/slow hands and vice versa tip).
They'll get back to you soon and hopefully you'll be able to share with the hive mind!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Ok, to heck with it: give me the link to SNB's file and I'll buy it. Curiosity has got the better of me and I want to see how he's done it. I've got mine working to the point that I'll post it too later today. I do have a ticket open with Racelogic about the bars.
Basic Site Sponsor
Basic Site Sponsor
I'm not asking you to buy anything I haven't! Hardware, or software!
Basic Site Sponsor
Basic Site Sponsor
Fergus, let me know if you have any trouble with it. I've used bars in the past and it was tricky to make work, such that I think you probably just missed something. The new approach I use (because I think it's cooler) was to make it a gauge. So it looks like a yellow line moving around the tach. My car is still at ATX getting repaired, so don't have something to experiment on right now to help you get the bar approach working, but I will help you the best I can without a car.
If you're curious, here's the info I sent to Racelogic:
https://www.dropbox.com/sh/xf6qxt15l...0wbvZq1Ra?dl=0
There's info there in a text file about the scene file I built (plus some videos and the scene files themselves) but the short story is that the right bar was working fine but the left never did. It was setup to fill right to left, with the minimum position at the right but it didn't work that way: when the left hand turn maths channel generated a value of 0, the bar was empty but as soon as it was higher than that, the bar would fill complete - indicating full left lock - then go *down* as the turn increased! Really weird.
I'm definitely interested to see how you did it, including the maths channel. I wish the GT4 just used a single value for angle and direction instead of separate channels.
I think SNB has the HP calc built into his GT4 scene. If not let me know and I'll help you.
Ok, I think I figured out my steering bar problem. I realize I’m kind of obsessing about this - I’d usually rather use Circuit Tools; the overlaid video is mostly eye candy - but it’s fun and perhaps someone will bump into the same problem and find this post.
Above I said:
“…the short story is that the right bar was working fine but the left never did. It was setup to fill right to left, with the minimum position at the right but it didn't work that way: when the left hand turn maths channel generated a value of 0, the bar was empty but as soon as it was higher than that, the bar would fill completely - indicating full left lock - then go *down* as the turn increased! Really weird. “
In this setup, the left hand turn maths channel was generating a number 1 through 470. I changed this around so that it now generates a number from 0 to -470. I then modified the bar so that it still fills right to left but the minimum position (-470) is now on the left side, instead of the right. Now it’s working perfectly. The maths channels look like this:
Right
-StrWhlAngle*(StrWhlDirection-1)
Left
(StrWhlAngle*StrWhlDirection)*-1
I’ll probably tweak my scene file to use the working steering bar then upload it here for anyone who wants to play with it.
Right
Left
Basic Site Sponsor
Basic Site Sponsor
Are the scene files for the VBox Lite and HD2 interchangeable? If not, can they be converted from one format to another? I have a VBOX Lite... wondering if I can move up to one of these fancy HD2 scenes.
Basic Site Sponsor
Basic Site Sponsor
No. Different file suffix. The Lite has a file size limitation on scenes that precludes the graphic levels capable for the HD2 scenes. I think if you've built Lite scenes, you can build HD2 scenes, but it's a different piece of setup software, too. Much easier to use than the older VBOX Setup, IMO.
There is a Lite Scene file, I'd need to modify it with a 8 Channel VBO file through to get the proper steering.
