Is there a way to make labels appear on the AIM color maps like show below? I did this using Powerpoint so that I could visually see where I could push the car more. Ideally I would like to have the G's and Speed show up in each corner, so I don't have to do it manually.
This might be easier to see if you use an absolute value of lateral acceleration, so the number is always positive. Math channel can do this...
If not:
Open a test
View menu - track report
Click settings for the track report - top right corner
Select the value you want to plot, uncheck show max and min click apply & exit. This will give you the banding.
Select measures tap on the left of screen
make sure you can see the little blue up and red down arrows next to the measures
Click the up and/or down arrow of the measure you want to show (lat g and speed)
I think if you select max Gs, and the min/max speed you'll get close, maybe not perfect.
Thanks for the help! I tried it and it works great. One more question, is there a way to add measurement points? Some corners don't have data.
Charley
not that I know of, can you repost your graphic? By the way, you're hauling in the bowl at chuckwalla. What are you driving?
Was that CW or CCW? My graph was CCW, which i prefer there. Lots of learning on my part, but really like this track for practicing throttle steer.
Charley
The actual segments in the Track Report function are based on the segments of the active track map. If you want different segments in the report, simply build a new track map (Map=>New) with the segments where you want them and when you save it your Track Report will be re-calculated with the new segments.
Rennlist Hoonigan which cost no drachmas Lifetime Rennlist Member
Rennlist Site Sponsor
Cool info. I didn't realize that is where the channel tag locations came from.
Do you have a map assigned to the data? Go to Map and then view. If view is grayed out, then go Map, Manager and assign or create a map for the data you are looking at. Then you should be able to do the track report.
