Clearance Prices on Sensors
Rennlist Hoonigan
which cost no drachmas
In doing some inventory cleanout, I came across some old pressure sensors still new in box. They are a little bit of odd range in 0-4 bar absolute and M10, but they are a great chance to add a sensor to things like coolant systems, airboxes, manifolds, etc. It would also work on carburetor fuel systems, diff coolers, and ??? It will also display as psi (if you want) on the dash and in analysis, so it's only important that you can use M10 and less than 45 psi (3 bar). If you don't have an AiM system, you can easily cut off the connector and wire it to +12v, ground, and sensor leads.
You can grab them for only $49.99 ($139 for the current sensors) at https://trailbrake.com/aim-0-4-bar-absolute-m10/ Quantity discounts too!
I've got some old MSI 150 pressure sensors that will be listed soon and an assortment of the old VDO can sensors. I'll get those added to the site as well.
Ask away with questions or if you wonder how it will work for your application.
Rennlist Hoonigan
I decided to add the 1/8 npt MSI 150 psi pressure sensors tonight. Check them out at https://trailbrake.com/msi-150-psi-1...essure-sensor/
Same low price of $49.99 and I only have two. These are great for anyone who thinks they want to monitor a fluid pressure like coolant, fuel pressure, oil pressure, etc.
Basic Site Sponsor
Basic Site Sponsor
Received 3,270 Likes
You have mail!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Rennlist Hoonigan
Here's a smoking deal. $10 for the old VDO can style pressure sensors. Some I have two sensors and only one cable, so I might send two! These are compatible with any AiM data system!
https://trailbrake.com/1-8-npt-vdo-pressure-sensor/
Rennlist Hoonigan
I'm throwing in an M10 to 1/8" NPT adapter with the sensors. They are perfect to measure anything up to 45 psi at a great price. Think about coolant pressure, carb engine fuel pressure, or??? They would also be great to measure pressure drop across a radiator or cooler, aero pressures with some ingenuity....
