Aim solo dL issue
Aim solo dL issue
Hi. I'm at cota this weekend and using aim solo dL w smartycam 2.1
Today, I noticed that whenever I would cross start/finish line, the solo dL would restart on its own. But smartycam is still recording. Obviously the time is always 0:00 since there is no lap time.
I never had this issue. Also realized that it isn't consistently charging - I am using Mworld hard wire plug n play solution - where you get the power from the obd pin. This was worked flawlessly for the past two years. Today is just weird.
Another scenario is that middle of the track, the aim solo resets (not necessarily when crossing the start/finish.
What should I do? I'm on latest firmware on aim solo dL. I think camera is also on the latest firmware.
I think I should just factory reset and go from there.... any thoughts?
Basic Site Sponsor
Basic Site Sponsor
Received 3,329 Likes
The firmware for both devices is pretty mature. I’m concerned about the charging issue. Not certainly how the M-World harness uses the OBDII for power, because that is on all the time. Typically power off/power on could cause reboots. Would not ignore the ground connection. Difficult to diagnose because the internal battery in the SmartyCam keeps it recording. Does any of the data drop out in the video, indicating no data sent from the Solo DL?
You have a very good point. Perhaps it's the ground connection of the hard wire. It is triggering a reset.
M world uses PIN number "x" wire which is power and slices it to piggy back to the aim wire of positive. And ground goes to "uhh forgot". It's been couple years since I installed it. But perhaps tomorrow, I will not use the "hard wire" for power but rather just fire it up and use internal battery for both the device and the camera.
Basic Site Sponsor
Basic Site Sponsor
Been my experience that both the SDL and SCHD need to be fully charged and will not last a whole lot more than a longer session. But that’s a good test!
I'll test it for one session.
Otherwise, I have to check all the connections in between sessions.
Thanks for the info. I'll come back w some updates
Basic Site Sponsor
Basic Site Sponsor
Good luck! Enjoy COTA!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Rennlist Hoonigan
which cost no drachmas
Certainly check the connections, but I'm betting on the recording parameters being set to not gps speed and RPM. The unit shuts off because it isn't recording and then the CAN wakes it up. Change the recording parameters to just GPS speed only more than 10 mph.
You guys are dead on with your diagnosis.
Wow!!!
Ground connection was severed. Just A subpar material and connection made by M world plug n play kit. I went to O reily store and had to splice/strip and crimp. Hilarious that I did this in the parking lot of Holiday Inn.
This is what desperation does to a man. Now I will go drink a cold one and sleep happy for another day of COTA tomorrow.
Thank you gentlemen!!!!!
Wow!!!
Basic Site Sponsor
Basic Site Sponsor
Wow!!!
Wow!!!
yours may be different, but we had a big problem with my AIM SOLO (not the DL though). we would charge it full, showed full charge and then it wold discharge in 10, 15minutes.
we had it monticello and it happened several times. we'd charge it out of the car with the wall charger, full charge and 10minutes into the session it would turn off.
we'd charge it and let it run in the trailer and it woudl lose charge really quickly.
it was swapped out. havent really had too much time with the replacement unit just yet. but it hasnt done that in the out-of-car test we did with it.
then again the first one didnt either for a normal discharges then went kaput.
i also think the backlight is too dark. i struggle to see thing though i can see the forecasted time, but any of the menu text etc. is impossible.
it needs a bit of work is my two cents.
I also find that if I haven't deleted sessions on the solo it will do what you're seeing. Just download and clear all sessions.
If Scott Landon is there talk to him. He's a guy I have helped.
Denis dot Clavette @ Comcast dot net if you want to chat more.
It is the ecu direct plug and play harness from M world. Their kit is bacially a ecu CAN bus wire modified to tap power/ground pin from obd port. That's all. CAN wires are still tapped in a different location than behind the fuse box (the typical harness wire bundle that people look for).
The advantage is that you can "power" it when you need to.
Major problem is that the wires that is mating with the obd plug is extremely thin and the joint butt connector just got severed in my case. They should've made a more robust connection and wrapped it around w more flex resistant taping etc.
Basic Site Sponsor
Basic Site Sponsor
