Aim solo DL. Can bus or OBD2?
Crosspost from the 997 section
I am finally getting around to installing my AIM solo DL. I want to get the most out of it in terms of data, but I'm also looking for the easiest install possible. Am I missing anything if I use the OBD2 port to collect data as apposed to hard wiring it in via the can bus system? If the latter is the way to go, can anyone help me out with some install instructions?
Basic Site Sponsor
Basic Site Sponsor
Received 2,800 Likes
Short Answer:
OBD II is easier to install
CAN gets you more data at consistent rates and improves data analysis
Long answer:
Using the OBD II protocol sets up the device to to operate using OBD II diagnostic protocol standards. It's not just reading data through the OBD II port, it's sending a DID read request and waiting for the ECU to recognize the request and respond. OBD II standards specify limited amounts of standardized data to be available. Because it is a request based protocol your data rate is whatever the ECU can provide at the time of the request. You may not receive a response every 10ms or 100ms. You might get data in 10ms, and then 30ms, and then again at 100ms, and then 10ms later. The more load on the bus the less frequently you get data.
Using the CAN bus connects you to a river of data. All the signals are transmitted at a constant volume and constant speed. Your logger just watches the data go by and logs it. If a signal is defined by Porsche to transmit at 100Hz (10ms) then you'll see it every 10ms every time (unless the transmitting ECU has a fault). The only limitation here is decoding the data. AiM has to reverse engineer the CAN database file. Your limitation on available data becomes what AiM has managed to figure out, and also how much effort they continue to put into an older model car once new ones come out and they shift focus to reverse engineering a new database file.
cbracerx (12-20-2021)
Rennlist Hoonigan
which cost no drachmas
I wondered the same and contacted AiM tech support prior to buying my Solo 2 DL.
Short Answer:
Long answer:
Short Answer:
Long answer:
When available, CAN connection is almost (99%) better than the OBDII connection. One benefit, with the Solo DL of both generations, is that the units is the same, it's just the wiring and config that varies. You can have 1 Solo DL and both harness for different cars, needs, etc.
Went I went from the Solo to the Solo DL on my Cayman S I did the CAN connection myself. When I moved the Solo DL to my new GT4 I didn't feel like hacking into the wiring and went to an OBD connection. For my purposes (I study my data and always try to improve) the OBD connection gives me just about all the data I can use. What it lacks is brake data. I recently added "Calculated Brake Pressure" to my Math Channels. There are some plug and play CAN connections available which I may try.
Sorry to revive an old thread but this is what popped up on Google when trying to diagnose my specific issue with my newly purchased AiM Solo 2 DL. I've got a 996 Turbo and had assumed it would work over my OBD II connection but after quite a bit of research and trying at least 3 different AiM protocols for Porsche I'm coming up empty and receiving NO data from the car to the datalogger.
This is my first attempt with a datalogging tool after several years of wanting to try it. Although having the GPS based lap timing and accelerometer data is helpful, I was really hoping for a bit more considering I can get the same GPS/accelerometer data from the much less expensive non DL version of the unit.
Additional background info: I was looking for a system that could be expanded upon to eventually do video with data overlays and thought the AiM unit would be the best route as I could integrate the camera at a later date but use the data now in their software to review lap times and corner speeds in the interim. Should I have tried a different setup for my 996?
Basic Site Sponsor
Basic Site Sponsor
You will need a direct connection to the CAN twisted pair of wires immediately adjacent to the fusebox in the drivers side footwell. You will get good throttle pedal position, engine RPM, coolant temp, brake on/off information, all of which can be placed on the background of the smartycam for useful review, plus a few more basic measures. Most good dealers have the correct cable and those with porsche experience set this up beforehand and send directions on the connection. Take a look for the 996 GT3 AiM threads. I've sold dozens of them.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Rennlist Hoonigan
Nope, no usable information over the OBDII. And only CAN information if the car is year model 2002 or later.
Thanks Peter and Matt for the responses. My car is a 2003 so I'll try to get the CAN cable from the dealer I bought the system from.
If anyone could point me in the direction of a thread on how to hook it up I'd appreciate it!
CAN-bus
When I got my AiM SOLO 2 DL from Matt, I requested a CAN-bus cable. He did include the correct cable. My local installer opened up the dash and did some splicing....all I know is that my AiM SOLO 2 DL and my SmartyCam are connected, and I get some nice video.
Unfortunately, just as with my former AiM MXL-2, I cannot rustle up the enthusiasm to do post session analysis overlaying the SOLO 2 DL's data on to AiM Race Studio 3. I think its partially an age things, no computers in the classroom when I was coming up. We were lucky to have a BCT 2, that';s a Big Chief Tablet and a #2 pencil. And a MS DOS/Windows software competence thing. If it wont run on my MacBook Pro, or function on my iPhone X, I am not that interested. Maybe if we had AiM Seminars out west earlier in the year, their first offering out here is this month, September, I would have been motivated to attempt to master AiM race Studio 3. But it didn't happen and I have been seduced by Apple iOS apps, such as Harrys Lap Timer, Track Addict, my favorite APEX PRO, Speed Box and the new Porsche Track Precision App. I have all of these apps on my phone.
I am rambling....,I need to go to bed, 2:10 AM PDT here.
So... I could not get the vendor I bought my unit from to supply the CAN-BUS cable so I reluctantly returned the unit to them for a refund.
I'm looking for a bit more data than the HLT can provide, but I'm coming up with too many different options and am looking for some advice...
Can anyone tell me what the 996 era folks are using?
What year 996?
