GPS lap insert problems
Old Oct 21, 2017 | 03:49 PM
doborder's Avatar
doborder
Default GPS lap insert problems
So this function has been working for me until recently.
I just went to the track yesterday and I am analyzing data today. I no longer have the GPS LAP INSERT function? It just blank and the gps map when you click this function just show a line? Did I do something? Any clues?
This happened once before and it went away when I updated the firmware. I just checked, I'm using the latest firmware. I'm on solo DL
THX
See attached pics
First one is what happens when I open up GPS lap insert
Second pic is when I press the gps select track
File Type: jpg
File Type: jpg
Old Oct 22, 2017 | 09:16 AM
Matt Romanowski's Avatar
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Sorry I didn't answer last night. I was on my phone and the photos weren't showing up.
I think you have a session that recorded while driving to the track. That starts on the highway based on the lat/long shown there. I'm guessing this data file is your drive to the track (or somewhere else). Double check the time stamp to see if it was the right date/time for your track session.
As a check, open another known good session and see if the GPS Lap Insert would work in with it. I don't see any problems using it on my install of 2.56.12
Old Oct 22, 2017 | 01:04 PM
doborder's Avatar
doborder
Lap inserts works with a session I recorded at the same track two weeks ago
Funny you mention the drive to the track
I actually had the entire Solo off on the way to the track
I usually keep it on lol
Old Oct 22, 2017 | 02:18 PM
Matt Romanowski
Rennlist Hoonigan
Export a kml and import it to Google earth and you'll see right where you drove.
Old Oct 22, 2017 | 02:32 PM
doborder's Avatar
doborder
Yeah
I did that and it shows 5 miles away from track... interesting
So should I just restart the solo when I get to the track then?
Old Oct 22, 2017 | 02:51 PM
Matt Romanowski
Rennlist Hoonigan
It will start and stop automatically when you go over/under 5 mph and/or ~500 rpm. No need to do anything else.
Old Oct 22, 2017 | 05:06 PM
doborder's Avatar
doborder
What I meant to say is, how do I ensure that the GPS captures so that I can do GPS lap insert with my old data. I need to use GPS lap insert so that I can compare my data from different tracks days to see if Im improving etc....
Old Oct 22, 2017 | 05:24 PM
Matt Romanowski
Rennlist Hoonigan
The gps records when the DL records. The session you posted the screen **** from wasn't a session on track.
You shouldn't have to use GPS lap insert all the time.
Old Oct 22, 2017 | 07:40 PM
ProCoach's Avatar
ProCoach
Basic Site Sponsor
From: Durham, NC and Virginia International Raceway
Periodically, it can pay to use GPS Manager on a Solo/Solo DL, wipe it clean and install all new tracks and ONLY the tracks you're going to.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Old Oct 22, 2017 | 08:53 PM
doborder's Avatar
doborder
Thanks guys
I did that last night
Cleared all tracks and put in New ones from gps manager
Old Oct 22, 2017 | 09:02 PM
Matt Romanowski
Rennlist Hoonigan
I've found that on occasion too, but it's not the problem here.
Old Oct 22, 2017 | 11:29 PM
doborder's Avatar
doborder
I was messing around this pm on GPS manager . I was trying load shapes into the track maps and found that several of my gpk files did not load. These are the same ones that I could not do GPS lap inserts on. So my guess is for some unknown reason my solo is not recording the gps file correctly thus I have a weird GPk file... I did what you guys suggested and loaded new maps so hopefully it will stop doing that. I did reach out to AIM so hopefully we can comeup with a solution.
Old Oct 23, 2017 | 06:33 PM
doborder's Avatar
doborder
Just to update the thread
I spoke with Mike at AIM SPORTS
Basically it confirmed what you guys have said
The solo recorded my drive up to the track so that is what is showing on gps lap insert
The solution is to either don’t power on the solo until I get to the track or
Down load the track laps individually so as to exclude the first lap
Thanks for all the input
Old Oct 23, 2017 | 06:38 PM
ProCoach's Avatar
ProCoach
Basic Site Sponsor
Great! Thanks for posting.
Old Oct 23, 2017 | 07:54 PM
Matt Romanowski
Rennlist Hoonigan
Did you download the whole event into one file? If so, try to disable the drive lap and then do the lap insert.
If you didn't clear the DL, then just download the data again and don't select that lap.
