Good glass cleaner?
I've got an issue, of all things, with my 2002 New Beetle and need a good glass cleaner. The inside of the windscreen has got a coating of 'something' (I'm guessing chemical off-gassing from the large dash plastic. This film causes basic glass cleaner like windex to show some patterns that define where the film is... when the moisture gets up and some slight fogging occurs, that film is really visible. Trying to 'rub' out the film with firm pressure is very difficult given how far forward that windscreen reaches inside of a New Beetle.
Are there any good glass cleaners that can be sprayed on a good cloth/paper towel and will actually remove those sorts of films?
Stoner's...there is no substitute.
PS...Stoner's now has a new tire shine out now also. It's aerosol spray on. I've tried all the rest, and this stuff is the best. As little shine as you'd like, or spray on another coat for more shine. Easiest stuff I've ever used. No rags. No mess. No dirty hands, fast, doesn't drip or run.
lasts forever...give it a try
Stoner's is good, but for this outgassing you might want to try applying some alcohol to a lint free cloth, going over the inside windows with that first, then use the Stoner's.
HTH
HTH
I've been using a homebrew which has never lost me points at concours.
Blend Isopropyl Alchohol with Distilled Water, 60% Alcohol/40% Water blend. Use this with a high quality lint free microfiber (available at auto stores) and you will end up with crystal clear glass.
We use the same blend to clean around the house, it works great on appliances, fixtures etc. and it sanitizes without chemicals.
Location: London,UK / Florida US State- Dazed & Confused
CorsaCloth – a glass cleaning cloth that cleans almost anything, leaving a streak-free, spot-free, dust-free and lint-free finish. This distinctive cloth cleans with plain water, it removes film, dirt, oil, grease, finger prints, dog nose prints, etc all without the use of chemicals, only water, and the result is a crystal clear finish
BTW I've also used stoners, prefer the alcohol/water blend.
Super Moderator
Needs More Cowbell
Needs More Cowbell
^ + 1 on the water/alcohol blend.
I would suggest a solution similar to what is used by RPTV ISF calibrators for safely cleaning CRTs, lenses and mirrors...
(IMHO, you still can't beat a good analog RPTV in HD)
Denatured alcohol and distilled water, mixed at 1:10 (a bit stronger if needed), a squirt bottle and glass microfiber towels. Spray on, let soak, wipe and repeat.
If you prefer commercial products, I like Stoners (spray) and Wurth Glass Cleaner (aerosol)
