Zaino Z8
The Penguin King
Is there a trick to applying this stuff. I'm having a hard time not getting smudges from it. I have to buff it out pretty aggressively to get a good finish from it. Right now, I'm not too happy with the stuff. Too much work for not that big an advantage, but maybe I'm doing something wrong?
Try removing what you have applied, with either a 50/50 water/alcohol mix or claying that area. Then apply a really thin layer, that you can barely see it. Zaino is designed to be applied in building layers, like painting....several light, thin layers are always better than one heavy coat.
I am sure other more experienced Zaino users can give you some nice tips.
Anthony
Did you prep the surface? Claying the car is very important. Also, if there is residual wax on the car (didn't use Dawn or equivalent) it can cause problems. Applying the wax in very thin coats, several, is also key. More is NOT better. We need more info...
The Penguin King
I'm putting the Z8 on top of Z2pro. I've got several layers of Z2 on the car. I love the Z2 product. It's easy to apply, and gives a really nice finish. I've experienced the mistake of putting too much Z2 on, so I know what you are talking about there. Maybe I just need to be more careful and put even less Z8 on.
Sal doesn't recommend microfiber. He says there is so much variation in what's on the market and they haven't really tested it with Zaino enough. Stick with 100% cotton toweling. Just barely spritz a section with Z-8 and start wiping immediately. The key with Zaino is, when you think you're not using enough, you're using the right amount.
I have heard of this from a number of Z8 users. I am sure that it only needs the very lightest of coats and immediate wipe off. IMO, Z6 is almost as good and is really easy to use.
As for the comments about microfibre cloths, I have read this before and am totaly puzzled. Is there a real problem of poor quaility cloths in the US? I have never heard of a problem in the UK. It seems so strange that Sal, a man who wants to transorm the way in which cars are "waxed", seems so close minded about what I think of as a wonderful product that is so vastly superior to cotton towelling!
(BTW, Rob, I hope you have sent me the Z5 Pro I ordered this week. The other stuff I bought a couple of months ago is great and yes, I am the guards red RS in Wimbledon!)
While I've never had a problem in applying Z8, I agree that it is not as easy to use as Z6. I only apply Z8 after a fresh coat of Z2 has been applied. I work in very small areas and spray a very little amount of Z8 on the surface and wipe off using microfiber. I never have a problem with smearing under these conditions.
less is more, keep it to a mist
Have used most Zaino products and agree that the key is to use as little as possible. One gripe I have is that the mist from Zaino products makes this difficult on both Z6 and Z8. Meguiar's spray pump puts out an ultra fine mist. I cleaned out that bottle and poured the Zaino in. Much better.
