Crunched side mirror
So I crunched the side mirror against the side of the garage. The housing is cracked and the mirror glass itself popped off. Is there a trick to getting the mirror glass back on? I can only do it if I take the cracked housing off and then hold the pivoting circle from the back. But then I cannot get the housing back on since the glass is in the way. Thanks.
matthewr87 (07-11-2024)
Thanks man. It turns out that the actual ring on the motor was dislodged which is why it was so loose and impossible to snap the mirror onto. I was able to get it back in place and the mirror reinstalled. Now I just need a top housing replacement......
Are you still under cpo? It shouldn't have come lose. You could always have the cap repaired vs replacing it. Just make sure a body shop takes off the mirror cap and doesn't spray on the car lol. You don't want over spray.
Hmmm looks like the unpainted top cover is ~$150 and the side marker lamp is ~$78. But the entire assembly including mirror and all internal components is $365....
The following 2 users liked this post by retom:
matthewr87 (07-11-2024),
NelsonLee (08-09-2024)
No luck on ebay sadly.
https://www.sunsetporscheparts.com/o...ist-9y0044830a
This says "painted". I'll have to reach out to ask whether that means I specify which color I want and it comes pre-painted, or if it simply means primed for paint.
So just as an update to this in case it ever helps anyone else. I was able to buy the mirror cover and the signal lamp from Porsche Delaware:
Part Number Part Name Price Quantity Total
9Y1-857-528-C-G2X Rear Cover $154.93 1 $154.93
9Y1-949-102-D Signal Lamp $78.08 1 $78.08
Total with shipping: $246.34
I then took the cover to a local Porsche certified body shop and had them paint it for $170.
Now I just need to wait for it to be slightly less hot and humid so that I remove the broken parts and replace with the new ones.
The day I spend $1500 for some carbon fiber mirror caps on a 6000 lbs family hauler is the day someone needs to contact the local loony bin and sign the papers.
I installed the new parts today. Took 10 mins; pretty lucky overall that it was just the cap and the signal light that broke. Could have been a lot worse. <$500 all in to fix my oopsie is quite good considering the Porsche tax on most things. Although if I went through the stealership it would probably be close to $1500.
