Sponsored By:
Sponsored By:
Engine control fault
Old Nov 28, 2023 | 01:32 PM
cosss94's Avatar
cosss94
3rd Gear
Default Engine control fault
Hello! This message just appeared on my Porsche Cayenne, it is somebody who encontered the Same problem ? I think it is a Little bit of lack of Power too, and in the morning at cold start, 0 degrees, the car shakes and it s working a Little interrupted, But this happened before that fault appeared. Thank you!
Old Nov 28, 2023 | 02:11 PM
kayjh's Avatar
kayjh
What model is this?
Old Nov 28, 2023 | 03:07 PM
cosss94's Avatar
cosss94
3rd Gear
Originally Posted by kayjh
What model is this?
2019 Cayenne 340 hp
Old Nov 28, 2023 | 04:36 PM
Schnave's Avatar
Schnave
Could be any number of things. Here’s some other threads discussing the Engine Control Fault:
https://rennlist.com/forums/cayenne-...-workshop.html
https://rennlist.com/forums/cayenne-...rol-fault.html
https://rennlist.com/forums/cayenne-...old-start.html
Old Nov 28, 2023 | 05:24 PM
sevasnex's Avatar
sevasnex
I had this on my new 2024 Cayenne a couple of weeks ago. Didn't notice a loss of power. The warning disappeared after engine restart. Dealer checked it and said "no error codes in flash memory". Whatever that means.
As noted above, it may be due to a myriad of issues. I guess, in my case it was a loss of pressure (I did opened and closed the gas tank cover after the warning and before engine restart).
Old Nov 28, 2023 | 06:21 PM
Schnave's Avatar
Schnave
If any of these sensors or actuators fail to communicate with the ECU or if the actuators fail, you’ll get the dreaded Engine Control Fault message.
Oh, for the simple days of a carbureted Chevy V8!
Old Nov 29, 2023 | 05:14 AM
cosss94's Avatar
cosss94
3rd Gear
This is the error code .
Old Nov 29, 2023 | 09:19 AM
Schnave's Avatar
Schnave
Turbo Underboost. The charge pressure sensor is telling the ECU the boost pressure is less than desired. Could be as simple as a leak in the air piping. Might be a bad diverter valve, Or it could be a failing turbocharger or waste gate.
Many threads on the p0299 code at Audi World forums:
https://www.audiworld.com/forums/sea...rchid=14938305
More here:
https://www.macanforum.com/threads/p...9-code.175900/
https://www.alexsautohaus.com/p0299-...ost-code-mean/
7 Porsche Models That Have Aged Like Fine Wine
Old Nov 29, 2023 | 07:56 PM
YHC's Avatar
YHC
P0299 is the one that I had to replace the water pump.
Old Oct 6, 2025 | 12:30 AM
996moe's Avatar
996moe
what did you end up doing? Was there a way to fix this issue?
Old Dec 15, 2025 | 06:25 PM
Install14u's Avatar
Install14u
3rd Gear
Default Find the fix?
I just took a 1200 mile roadtrip and had the exact same symptoms as I started up this morning in 18deg temps. Codes came in at about 100 miles after starting my travels. Scanned it when I got home to see this code. Performance was down a little but highway driving.
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
