Cayenne E-Hybrid Charger
I went to the Porsche dealership today because my check engine light was on in my new 2022 Porsche Cayenne E-Hybrid (Code P0306) - Cylinder 6 misfire detected.
They swapped five and six out and everything seems to be working fine.
However when I was there they said there is a Factory Campaign open on my Porsche Mobile Charger. I have to bring my car in for a full day when they can get me a loaner (4 weeks). Does anyone know what the issues is with the charger?
Thanks,
Thanks,
According to the NHTSA this affects the 2021 Turbo SE and the 2021-2022 e-Hybrids with the 7.2 kW On-board Charger.
https://www.nhtsa.gov/vehicle/2022/P...Communications
Here’s the technical background:
The on board charger mistakes disturbances in the electrical infrastructure (power grid) and/or charging hardware (that sketchy charging station at Walmart) as an internal fault. The OBC then needlessly shuts itself down and leaves you with an uncharged battery. “Customers affected by this are encouraged to evaluate and modify their charging habits (for example, use a different electrical receptacle, a different circuit, or different charging hardware).
https://static.nhtsa.gov/odi/tsbs/20...15465-0001.pdf
Here’s the fix:
Information: Various symptoms during or after charging the high-voltage battery, e.g.:
https://static.nhtsa.gov/odi/tsbs/20...15460-0001.pdf
Here’s the fix:
- Charging of the high-voltage battery not possible or charging process is aborted
- Check Engine light in the instrument cluster after charging or charging attempt active
- Fault memory entry ’U112100 – Data bus – missing message (D1211D)’ stored in the fault memory of the high-voltage charger (OBC) control unit
The following 3 users liked this post by Schnave:
The TSB applies to the vehicle’s on board charger. It converts the 110 or 220 AC voltage from the wall charger to usable DC voltage that actually charges the battery. It is located behind the charging port as illustrated below:
The following 2 users liked this post by Schnave:
Needsdecaf (08-29-2022),
poolie (08-28-2022)
I appreciate the information. All I know is that I have to take my car in and they want me to bring in my portable "wall" charger. Maybe they want to do something with my onboard 7.2Kw charger and my portable wall charger.
I will update when I go back. Thanks for all the information.
Schnave (08-26-2022)
Interesting.... I had my 2022 eHybrid die in the drive overnight while on charge a few months ago. Car went into full UVP mode and had to get a jump start to get it going. I did contact my dealership but never really got an explanation, certainly the battery condition, charging etc was all showing as fine. Hasn't happened again but now I don't leave the car charging overnight which at least limits the risk of issues with the mains.
No word of a factory campaign here though.
Calum
Calum
Calum
Calum
I'm also waiting on our second key fob and when my SA placed the order for it, she mentioned that there are a few factory campaigns that need to be addressed as well. One specifically is for re-coding the passenger door control unit.
https://static.nhtsa.gov/odi/tsbs/20...10768-0001.pdf
According to the document:
The control unit is held in standby mode due to an internal fault in the door control unit on the passenger's side (front door). As a result there will be an increased closed-circuit current load and the 12 V vehicle electrical system battery will become discharged while the vehicle is parked up.
I am suspecting this is what is caused the 12V battery to discharge and go into UVP. This might also be the reason why our alarm goes off randomly often. Have you experienced your alarm going off randomly?
Schnave (08-28-2022)
Hi Lphiesmacks10,
my car was delivered end Nov last year and it came with both key fobs so no issue there.
Although I said no word of a factory campaign i was referring to this latest one mentioned above re the charger. Car has been back for a couple of campaign things including with respect to the electric steering adjustment which hasn't been and won't be delivered : (
Sorry to hear about your battery issues thankfully (fingers crossed) my problem so far has been a one off. That said I did rush over to Amazon at the time to get one of the CTEK 12v lithium battery chargers, just in case.
Calum
Calum
The "wall charger" is actually not a charger. It's properly called an EVSE: Electric Vehicle Supply Equipment. It's basically a "smart" extension cord which allows the vehicle to monitor voltage, allow current to flow, etc.
The actual charger is on board the car.
daveo4porsche (08-29-2022)
Hi Blackrider,
post an update and let us know how you get on at the dealership
Thanks,
Calum
Thanks,
Calum
I'm not trying to be a jerk, but want you to understand that if they say "we need to replace the charger" or if they are reprogramming the charger firmware as per the bulletin he posted, they are talking about hardware that's inside your car, not the cord that came with it (or you bought separately).
I had my '22 e-hybrid in for what I think is this problem. They wanted my charger and told me they wouldn't do any work unless they could reproduce the problem in their shop. Needless to say in the 2 times they charged the car it didn't throw the code, so they said it must be something with my infrastructure. They wouldn't tell me what the code is exactly, but I'm sure that it's this problem. They also wanted me to bring in my "charger" (cabling), but of course it tested out as being just fine. I think I'll print off the PDF documents for next time it goes in for maintenance and leave it on the dashboard.
I have a 2022 Cayenne E-Hybrid. I finally got the information on the MOBILE CHARGE (See above) campaign. The service advisor was very vague on what was done. All she said is that they "put a sticker on it" and gave me an updated manual (more like a 4 page addemdum). I do not see an external sticker so I am not sure what was done or where this sticker was placed. Below is a screen shot of the work that was done. Maybe someone here can help me dicpher what the hell was done. I did overhear that it was the same campaign that the Taycan was undergoing.
What was actually wrong. Were there major issues?
I was looking around the internet for code WMP2 and found this: 05/16/202: Unspecified WMP2 VOLUNTARY SERVICE ACTION - REWORKING CHARGING ELECTRONICS (PORSCHE MOBILE)
After more research I found out what was going on: The campagin lowers the amperage. The dealership updated the software which would lower the charging amperage because customers had complained about overheating. The new "lower" amperage is a "default" setting that is easily overridden with software settings. Porsche is not hardcoding or limiting their Porsche Mobile Charger but rather making the initial default setting less demanding which slows the charge rate. In all cases you can still set it to the full 40 amps of charging capacity.
The following 2 users liked this post by BlackRider:
MKC91 (03-01-2023),
Mulacttocs (09-22-2022)
