Looking for GTS or Turbo (V8) Oil Change Procedure
#62
@chassis “Are you talking about the large diameter (approx 3") rubber snorkel tubes from air cleaner assembly to turbos?”
That’s correct ..!
Btw the entire procedure may have taken around under 3 hours for the oil change that’s because I was cleaning the underside while I had the covers off.
also any idea where the MAF sensor is located on this engine ?
That’s correct ..!
I did some digging for the MAF and all I came up with is pressure sensors up- and down-stream of the turbos, plus throttle angle and engine speed. My assumption is mass air flow is calculated from those parameters.
#63
chassis (02-03-2024)
Greyphantom (02-04-2024)
chassis (04-27-2024)
#68
I just completed this Cayenne V8 oil change this morning on my 2022 Cayenne GTS. It was very helpful to have some guidance/suggestions. I actually completed this job in just over 2 hours and 15 minutes. Granted, I'm pretty handy with DIY and have all needed tools, but with some guidance I fould job not nearly as difficult/time consuming as many had warned. If Porsche is charging 4 hours for this, they are making a nice profit, since I would assume they could complete in 2 hours. Next time I will not delay my oil change fearing a massive time investment.
The following 2 users liked this post by TeesTurboS:
chassis (04-27-2024),
Greyphantom (04-27-2024)
#69
Those are the buggers. I firmly hold the trim panel with both hands as close to the white "fir tree" push pin as possible, and lift straight up. The white pin gets chewed and mangled each time, there is no way to avoid it. Removing the clip is an option I will evaluate next oil change.
#70
Greyphantom (04-28-2024)
