Water fluid leaking from backup camera?
https://rennlist.com/forums/cayenne-...l#post17491026
Once you have removed that big trim piece, you will see this. The blue box shows where the camera/check valve connections are in the hatch (and I guess the license plate lights). The orange circles are most (if not all) of the clip connection points where the trim piece mounts to the hatch.
One last bit of documentation. If you find the Center Taillight Removal thread and look for the replacement part to the metal clips, you'll end up with a part number that provides a smaller (shorter) clip. Part "8" from the diagram below is what I ordered, but what I got looked more like Part 2 (and I confirmed/ordered the part with my local Porsche Parts counter).
https://www.lllparts.co.uk/catalogs/...1/8/807/807040
Fear not. The smaller ones work fine. Original/taller clip on the right (that I slightly mangled). Smaller clip on the left. You can see that the important parts of the clips are basically the same size.
