2020 Cayenne S Dash Cam Install
Hi,
I'm planning on getting the 2 channel Blackvue dashcam and I just want to make sure I am not missing anything before I begin installing it so I can minimize the chance of breaking something. I have tried searching on google and youtube for videos of installation on the new Cayennes but came up short.
1. Does anyone know if the A-pillar can simply be gently pried off with a plastic trim tool or there's a screw that needs to be dealt with under the airbag logo?
2. Can all of the front/back doors' and rear tailgate's weather stripping be easily pulled off like other cars or are there additional steps I need to take? Are they glued on?
3. Can the wire be easily slipped behind the B-pillar with a plastic trim tool without taking the B-pillar off?
4. Are there any hidden screws on the rear tailgate's upper trim or can it just be pulled off with tool?
Thanks in advance for any help!
Hi,
Check out this post for the a-pillar trim. same clip mechanism. https://www.audiworld.com/forums/q5-...e-rhd-2950468/
Pls note reinstalling the a-pillar trim was a real PITA.
Yes but there is no need to pull it. You need to pull the lift gate wire harness seals and fish the dash cam coax cable through it.
I ran it down the a pillar and then along the bottom of the floor to the rear of the vehicle. found it to be too much of a pain to run above between the headliner. it's just too tight.
No screws. just a bunch of metal clips. Pry tool at the right locations will do the trick.
Hi,
On another note, for extra security against abrasive wear/shorting overtime I'd recommend wrapping the dashcam wires with tesa wire loom tape.
Sorry to bring this thread back to life but I can't for the life of me see that clip to remove.
Trying to install a 2-ch dashcam and I can't stuff both wires in the weather strip.
Any suggestions on how to remove the a-pillar? Just afraid I might break something...
Thanks in advance.
Thanks in advance.
Hi,
Hope this helps.
On my X5, BMW added a software update and now it automatically saves 30-60 seconds clips prior and after an accident from all four surrounds cameras. There's also a shortcut button to use if you want to manually save the 60 seconds prior to an event. It is such a nice feature that acts better than a dashcam. I wish Porsche thinks about adding a similar feature which will be much more neat
