aluminum sport pedals
Note, Rennline's pedal for the Cayenne does not fit properly on a 2017. They're aware of this and are working on something. Hopefully by the time I drive by there place this August during a Summer vacation trip to Vermont (to return the ill-fitting one, and the phone mount which also doesn't fit the '17).
The factory dead pedal in the '17 is a large plastic one. Previous years were just plastic/vinyl bumps on the carpet. The current Rennline offering doesn't fit properly over the larger one now in the '17. It's off, slightly too wide and a bit too short. You 'can' use it but for the money it ought to be something that fit properly. It looks exactly like the factory pedals (brake and accelerator).
The aluminum pedals I ordered on E Bay finally arrived from China. I bought these on April 24th, showed up today on June 10th ... they must have LITERALLY taken the slow boat from China
Here's a pic of what they sent me. While I ordered the non-script version, they delivered me a script version .... oh well, what should you expect for $24 ...? I'll install them this weekend and post up a few pics
just installed sport pedals in my 958 tts. they were made by brian at SRP RACING. easy install - gas pedal and footrest attach by sheet metal screws into plastic. brake is steel so a little more effort to drill through ( do yourself a big favor and buy some NEW good quality drill bits ). very happy with srpracing - go to website to see several styles and finishes . mine are a light silver (close to the finish on the case of my apple laptop ). dan
I Finally Installed My Aluminum Pedal Set!
I finally found some time to install my aluminum pedal set on my 2012 Cayenne S today. I had the OEM pedal set that actually just fits snugly around the pedal itself, so the uninstall from stock took about 3 seconds. Here's the factory pedal set:
Then I installed the dead pedal. I didn't have a factory dead pedal so this alone was a vast improvement
Then I had to drill through the metal brake pedal and the plastic gas pedal to thread the Allen-head bolts through the pedal, secured with a simple nut at the back.
All in, this took ~30 min, only because my beat-up drill bits struggled to get through the metal brake pedal. Now that I've got these installed, I am really pleased with the result as these were an impulse purchase from a Chinese seller on EBay and I wasn't sure I was gonna like 'em. But here's the final result, which I figure looks pretty dang good for a $24 pedal set
Then I installed the dead pedal. I didn't have a factory dead pedal so this alone was a fast improvement
All in, this took ~30 min, only because my beat-up drill bits struggled to get through the metal brake pedal. Now that I've got these installed, I am really pleased with the result as these were an impulse purchase from a Chinese buyer on EBay and I wasn't sure I was gonna like 'em. But here's the final result, which I figure looks pretty dang good for a $24 pedal set
north shore, i got them as well, same as you i ordered non script but got sent the scripted ones. however they shipped mine within a week - really quick. they aren't too bad but i have ordered a set from srp racing (RL member recommended see earlier posts ) they are making a set from my patterns as they did not have for the 958. expect them soon and will post pictures when i receive. dan
Dan...If you still have that ebay set, I'll buy them off you. Shoot me over a PM if you want to sell them. I want to swap the stock ones out. I may get nicer ones down the road, but at least let me get something there for the time being...especially the dead pedal.
Good luck with the install, and make sure to have a good drill bit to get through the metal brake pedal (my beat up bits made that the longest part of this install...). Post up some pics when you're done
Now go find your vacuum cleaner!
Unfortunately, a filthy carpet is the least of my problems at this point... my 20 year old son did this to my Cayenne s in Friday afternoon. Nobody was hurt- thank God - but the interior cleaning will have to wait a few weeks until I get it back from the body shop😬
